Author Topic: How to remove the lower middle front grill?  (Read 7843 times)
Offline Robert74
« on: October 19, 2010, 01:55:26 pm »
This is the grill under the number plate. Does anyone know the best way the remove/change this as mine is broken?
2006 GTI 5 door DSG
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ln9ib5hb9vhljsul8jjjm1pq54&/topic,19740.0.html
Re: How to remove the lower middle front grill?
« Reply #1 on: October 19, 2010, 03:40:45 pm »
AFAIK it just pulls out.... youll need a plastic wedge of some sorts OR if your carful a screw driver to pry it of the clips!
Offline vRS_Pagey
  • -Receive: 59
« Reply #2 on: July 17, 2011, 07:29:04 pm »
Bit of a resurrection, but can someone just confirm how to do this as I want to wrap my GT grill - top and bottom.
Offline Little_Dave
« Reply #3 on: July 17, 2011, 11:50:10 pm »
Had my grill off the other day mounting number plate surrounds, need to lift the bonnet and take out the 2 screws holding it at the top and then take out the 2 screws hidden inside the top of the honeycombe grill in the centre and then lift it off the car, didn't take the lower section out but looks like its just a case of levering it out and lifting it up and forwards to remove from the car
hope this helps
Dave
Offline big al
« Reply #4 on: July 20, 2011, 04:21:12 pm »
Just make sure you remember the 2 screws under the number plate plynth area, if you lie down and look up at the grill you will see it.
Bottom part just pulls out with clips, no screws involved.
Offline Lyons
  • -Given: 18
« Reply #5 on: June 01, 2015, 11:58:30 am »
Just bumping this up to save starting a new topic. Does the main grill need removed before the lower 1 can be taken out? I've tried pulling it but cannot get the thing shifted!
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #6 on: June 01, 2015, 12:43:24 pm »
Bottom grill is clipped in. I use a trim removal tool wedged in to force it to unclip.
Jas
VCDS (Preston, Lancashire)
Offline jaffa
  • -Receive: 44
« Reply #7 on: June 01, 2015, 03:14:26 pm »
I think the 2 bottom screws from the top grill screw through the bottom grill
