Author Topic: Which intercooler  (Read 10608 times)
Offline craig_t
  • Craig
Which intercooler
« on: December 19, 2010, 06:37:06 pm »
Can anyone shed some light on intercoolers for me. I'm getting my car ready for stage 2 and iv been told to eliminate heat soak by uprating my intercooler, but I'm not sure what to go for. Iv been recommended that an S3 one is a good option.
Can anyone point me in the right direction as iv seen a few different intercoolers and not sure which will be the best.
Admin notice, sig pic removed for being to big.
Re: Which intercooler
« Reply #1 on: December 19, 2010, 06:43:39 pm »
Try a Search and you should come up with lots of info and discussion about this.
Broadly, your options are:
- S3 - oem VAG approach.
- THS - Very highly regarded. Better performance reported than the S3, but S3 is still good.
- APR - Highly regarded but very expensive.
- Forge Twintercooler - Front mounted and can be used in conjunction with any of the above (except possibly APR?) and also the stock intercooler.
« Last Edit: December 19, 2010, 06:45:58 pm by RedRobin »
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: December 19, 2010, 07:16:55 pm »
take into account fitment costs as well.  The S3, THS, APR intercoolers are a bit more involved than the forge twintercooler, so labour will be more, potentially cancelling out any savings.
Offline craig_t
  • Craig
« Reply #3 on: December 19, 2010, 07:26:05 pm »
can you have twintercooler with stock??
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: December 19, 2010, 07:28:57 pm »
thats its main design.  However it will be usable with all the others with minor adaptions.
Most use it along side the stock cooler, others have paireds it with the S3 cooler for top results.  Think PDT has some good deals on iirc
« Reply #5 on: December 19, 2010, 07:32:24 pm »
.... *cough*:
Offline robern2
« Reply #6 on: December 19, 2010, 07:33:15 pm »
I have the standard intercooler and the twintercooler, it's an excellent combination on the ed30.
Offline GTIite
  • Build it.. don't buy it!!
« Reply #7 on: January 03, 2011, 08:32:15 pm »
Hello, be looking at getting an intercooler pretty soon and as Ive been reading it seems a cheaper option to get an S3 intercooler than the Forge Twintercooler which I was looking at. My car is not a ED30 would the S3 Intercooler still work?
Also any idea of the price of the S3 intercooler and where I could buy one at a good price?
Thanks Ash
I have ETKA and ELSA - Happy to help if anyone needs anything. Instagram - @f11tvw
Rotiform VCE's : US Spec Rear Bumper : Colour Coded Side Skirts : US Grill : De-Wipered : Revo Stage 2+ Map : Revo Intake : Revo throttle pipe : THS Intercooler : K04 Conversion : Milltek Cat Back + Pipwerx Decat : Sachs Stage 3 Organic clutch + Single mass flywheel : Quaife ATB Differential : S3 Brakes + Vagbremtechnic discs : Full SuperPro Bushes : SuperPro ARB
« Reply #8 on: January 03, 2011, 09:14:27 pm »
JKM have it for £330
« Reply #9 on: January 03, 2011, 09:20:02 pm »
Thanks Ash
The forge IC, by far, out performs the S3 cooler, and the S3 cooler is a lot harder( more time consuming ) to fit. If you are fitting yourself then the S3 cooler works out a good option, but if you pay a garage to fit it, then you might as well go for the forge as it's cheaper to fit, but more costly to buy.  That made sense when i started.  :laugh:
Offline craig_t
  • Craig
« Reply #10 on: January 03, 2011, 10:03:19 pm »
Yeah I get what you mean, it's looking like I'm gonna get a twintercooler now anyhow and keep my stock ic. Does anyone have this set up and able to comment on performance increase??
« Reply #11 on: January 03, 2011, 10:07:53 pm »
It doesn't give much of a performance increase on it's own, though the accelerator feels more crisp and free flowing, but what it allows is the timing to be advanced more which means more power, also you get less heat soak in the summer. If you are tuning a engine then this is a great add-on.  :happy2:
Offline craig_t
  • Craig
« Reply #12 on: January 03, 2011, 10:27:45 pm »
Yeah I'm getting bits together ready for stage 2 and this along with hi flow cat and down pipe and hpfp are part of my plans. Do you actually have a twintercooler ?
« Reply #13 on: January 03, 2011, 10:28:50 pm »
Yes pal, and a s3 one too.  :wink:
Offline craig_t
  • Craig
« Reply #14 on: January 03, 2011, 10:40:05 pm »
Are you running stage 2??
