Author Topic: Edition 30 steering wheel & leather seat trim.  (Read 5592 times)
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« on: January 12, 2011, 09:19:36 am »
Best product to use on the steering wheel to keep the nice mat black finish & keep the part leather seats in top condition.  :happy2:
Re: Edition 30 steering wheel & leather seat trim.
« Reply #1 on: January 12, 2011, 09:54:52 am »
If you have a look through the detailing threads for "leather", you'll find the answers.
Basically, the ED30 leather is coated with plastic so leather cleaners and conditioners are a waste of time. Use dilute all-purpose cleaner and use a brush to ensure any ingrained dirt is shifted. JPC has written some more detailed posts about this.
Any "dressings" will sit on top of the plastic layer and provide no benefit.
Offline craigy123
  • -Receive: 24
« Reply #2 on: January 12, 2011, 11:14:21 am »
Werkstat Satin Prot
http://www.polishedbliss.co.uk/acatalog/werkstat-satin-prot.html
ive been using this for a while now on my "leather" and interior plastics apart from the steering wheel, it just gets a wipe down with diluted APC. Works great, doesnt leave a horrible tacky shine.  :happy2:
PM for details
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #3 on: January 12, 2011, 12:20:40 pm »
Thanks guys so autoglym leather balm would be a wast of time? :sad1:
Offline craigy123
  • -Receive: 24
« Reply #4 on: January 12, 2011, 12:25:58 pm »
Correct, unless you wear leather trousers? cause it will just rub off onto your clothing  :grin: . The above Prot is good stuff. The leather balm from AG if i am right is designed to be absorbed into the leather and nourish it, the plastic part of our cars leather wont allow this to happen, therefore it will just sill on the surface.
A good wipe down with an APC, Meguiars for example also leave a clean, matt finish.
PM for details
Offline keith
« Reply #5 on: January 12, 2011, 08:42:20 pm »
I just use the AG leather cleaner.
Offline Fastmonkey
« Reply #6 on: January 13, 2011, 03:54:53 pm »
Is this same as the leather in the mk5 R32 ?
MK5 R32 DSG Build thread   -  http://www.mk5golfgti.co.uk/forum/index.php/topic,23512.15.html
MK2 VR6 Vortech Charged
« Reply #7 on: January 13, 2011, 06:19:39 pm »
Okay I found the original thread: clicky
Quote
Most leather in our cars is matt when it is new and looked after correctly. Leather with a shiny or glossy look is usually due to build up of dirt together with abrassion (constant sliding in and out) and this is often exacerbated by the use of 'conditioners' that contain waxes and/or oils which only sit on the surface and attract more dirt.
Leather does not require 'conditioning' with anything other than water.
Keep your leather clean by protecting it with a leather protector and then regular cleaning.
Adding 'conditioners' which generally contain oils and waxes will change the appearance of your leather over time as dirt will build up on the surface and cause a sheen.
Using the correct care methods and products will not alter the factory finish.
Your type of leather is 'coated' leather. This is essentially a 'painted' leather with a clear coat finish over the top. The leather may or may not be dyed through with aniline dyes prior to the finish coating.
Essentially it is this top coating that needs looking after. Cleaning is vitally important as the top coat will wear away if allowed to become dirty. Dirt on the surface will aslo become ground into the finish by constant abrassion.
'Conditioners', balms, feeds etc (traditionally oil and wax based) cannot penetrate this finish so are not worth applying - they can also leave behind residues on the finish which will only attract more dirt if allowed to remain.
A protector will make the finish easier to clean and also inhibit dye transfer etc on pale coloured leathers.
Leather however finished has to remain breathable and it will allow the movement of moisture back and forth (transpiration) so the use of water based cleaners and protectors will keep the leather correctly hydrated which is essentail to keeping it in good condition.
The routine for correct care should be
Protect from new (Auto Ultra Protect)
Maintain with a regular clean or maintenance product (Auto Ultra Maintain)
Deep clean with a foam cleaner once or twice a year (Auto Ultra Foam)
This will prolong the life of the finish on the leather
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #8 on: January 13, 2011, 09:14:11 pm »
Thanks for that,will just get some decent leather cleaner. :happy2:
