Author Topic: Sunset Red 1.4 TSI(TFSI) GT Sport - daily drive & track car  (Read 701599 times)
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: Sunset Red 1.4 TFSI GT Sport - daily drive & track car
« Reply #390 on: May 25, 2012, 10:14:55 pm »
I also think the old one looks fine. Have you ever measured the coils?
"You get what you pay for."
Offline fuscobal
« Reply #391 on: May 26, 2012, 06:29:06 am »
It's the same sparks I'll install once my engine work is complete ! HAd them in the past and worked smoother than OEM but were prone to blowing during the cold winters !
Mk5 GTI 6MT - Revo stage 3
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #392 on: May 26, 2012, 05:58:06 pm »
Thanks guys! The coils are great. They even seem smother than the OEM ones (NGK Platinum).
Holger what do you mean my measuring them?
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #393 on: May 26, 2012, 10:56:59 pm »
I thought of you misfire issues. Have you checked the coils? Guess there might be a way to measure their resistance.
Offline fuscobal
« Reply #394 on: May 27, 2012, 07:12:10 am »
Rex, they are smoother also because they are new :)
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #395 on: May 27, 2012, 08:30:23 am »
The coils are new. So there shouldn't be a problem there.
I will check for deposits on the valves that might prevent them for closing fully (as I understand this is a common problem with direct infection engines).
Offline fuscobal
« Reply #396 on: May 27, 2012, 08:50:22 am »
Yes, it is. After 80.000km mine was choked by deposits. However, now, at 110.000km my engine was clean inside !
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #397 on: May 27, 2012, 04:05:30 pm »
I now have almost 70.000 km so it might be time to clean the valves. Thanks for the info!
I will check this next week, before another track day at Hungaroring.
« Last Edit: May 28, 2012, 08:29:10 am by rex »
Offline jimk04
« Reply #398 on: May 28, 2012, 07:20:25 am »
How do you clean the valves.....and keep them clean?!
Cylinder head off or a fuel additive?
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #399 on: May 28, 2012, 08:15:21 am »
Since the fuel never reach the valve stems as it's injected directly into the cylinder there's no idea in using fuel additive for this specific problem  :wink:
Over the top mod list ;o)
Offline jimk04
« Reply #400 on: May 28, 2012, 07:56:36 pm »
Oh yeah :ashamed:! :happy2:
So head off job?
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #401 on: May 28, 2012, 08:17:39 pm »
Or use a oscilloscope (I hope this is the English word for it).
I talked to a mechanic and I will use this tool to see if there are deposits ore if I have any problems with the timing belt (mine is on chain so hopefully no problems here).
« Reply #402 on: May 28, 2012, 08:21:13 pm »
I think you might mean a borescope.  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #403 on: May 28, 2012, 11:59:53 pm »
In German: "Endoskop" to have a look into engine internals.  :evilgrin:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #404 on: May 29, 2012, 07:24:08 am »
I made a more detailed search and it seems it is called oscilloscope. It is used on cars also:
http://en.wikipedia.org/wiki/Oscilloscope
http://www.alibaba.com/showroom/automotive-diagnostic-oscilloscope.html
http://www.autoditex.com/Download/Oscilloscope_FAQ_en.pdf
By interpreting the data it will be able to tell me if there are any timing belt problems or deposits or many other issues.
