Author Topic: JKM Rolling Road June 18th  (Read 118942 times)
Saint Steve
Re: JKM Rolling Road June 18th
« Reply #480 on: June 19, 2011, 08:46:19 pm »
just a thought, all the cars that claim to have run accurately, were new cars??
Would having lower tread on the front wheels cause differences in RR readings??
If all models of cars were strapped down the same, yet the newer cars ran nearer to their Pre claimed bhp..
Anyone with a a mk5 GTi running new tyres and what bhp did you get yesterday? Maybe tyres not gripping aswell.
I know Jim commented on my vreddestein tyres not getting enough heat in them causing issues on my 1st few runs before.
« Last Edit: June 19, 2011, 08:50:06 pm by Saint Steve »
  • -Receive: 453
« Reply #481 on: June 19, 2011, 08:46:59 pm »
His issue was down to dsg, the power was similar before and after...
Ahh, ok! Was just hypothesising why the discrepencies may have occured.
  • -Receive: 453
« Reply #482 on: June 19, 2011, 08:50:16 pm »
As long as there was no wheel slippage on the dyno then variation in thread depth would make no difference.
Saint Steve
« Reply #483 on: June 19, 2011, 08:51:58 pm »
but would tyres not being up to temperature cause an issue Bacillus?
Offline Creatz
  • The Noob
« Reply #484 on: June 19, 2011, 08:59:46 pm »
I'm sure JKM would love to comment on all of this but i hear there busy modifying a yeti
:signLOL:
Saint Steve
« Reply #485 on: June 19, 2011, 09:01:45 pm »
I want a yeti  :sad1:
Offline Jussa
  • Bicester
« Reply #486 on: June 19, 2011, 09:03:46 pm »
I think the F*&%kin Yeti ate all my Horses  :confused:
Offline Creatz
  • The Noob
« Reply #487 on: June 19, 2011, 09:07:28 pm »
:signLOL: :signLOL: bring the shotgun next time
Offline Jussa
  • Bicester
« Reply #488 on: June 19, 2011, 09:08:13 pm »
 :signLOL:  :signLOL:
  • -Receive: 453
« Reply #489 on: June 19, 2011, 09:08:23 pm »
If the tyres weren't up to temp then they will have a slightly lower pressure. This should only have a minor effect when the dyno is trying to calculate the coast down losses to convert wheel hp to crank hp.
The above again assumes that no tyre slippage has occured on the dyno.
« Last Edit: June 19, 2011, 09:11:39 pm by bacillus »
Offline Jussa
  • Bicester
« Reply #490 on: June 19, 2011, 09:09:43 pm »
Well my tyres are not new..... :sad1:
Offline alackofspeed
  • -Receive: 24
« Reply #491 on: June 19, 2011, 09:36:51 pm »
The dyno dynamics RR works on a default loss calc, there is no run down loss check. I enquired of JKM after everyone had gone, as I was curious to understand how they work out the losses on a DSG, which to my knowledge isn't meant to be turned at high speed in neutral.
« Reply #492 on: June 19, 2011, 09:39:35 pm »
....That's right - DSG and kickdown. Found not to be an issue but JKM wanted to be sure what was happening.  :happy2:
« Reply #493 on: June 19, 2011, 09:41:17 pm »
....Me too - I need new fronts. I check my pressures very regularly though.
« Reply #494 on: June 19, 2011, 09:50:31 pm »
