Author Topic: clay bar  (Read 2496 times)
Offline critter
clay bar
« on: March 07, 2011, 08:41:36 pm »
Hi clayed the car for the first time at the weekend,cant believe the differance,such a great product.
     Is it safe to do regular,because i think im hooked.
Offline SimonBash
  • -Given: 22
Re: clay bar
« Reply #1 on: March 07, 2011, 10:52:27 pm »
It does do a great job of removing bonded contamination.
As long as you have protected the paint with wax or a sealant you probably don't need to clay it for another 6 months.
Even careful claying with plenty of lube and a mild clay can leave some marring so best no to over do it.
« Last Edit: March 07, 2011, 11:29:28 pm by SimonBash »
Re: clay bar
« Reply #2 on: March 07, 2011, 11:00:44 pm »
As above. Claying doesn't need to be done more than twice a year. You would gain no benefit but risk likelihood of marring. I'd follow any claying session with a polish. Use adequate lubrication - bilt hamber clays use water as lube. Personally prefer the dodo juice stuff.
And finally, protect your finish with a wax or sealant.
Offline SimonBash
  • -Given: 22
Re: clay bar
« Reply #3 on: March 07, 2011, 11:09:28 pm »
My current fave clay is dodo juice gentle grey with meguiars last touch diluted 1-1 with water as lube.
Meguiars own mild clay is not bad at all, same goes for autoglym clay.
Dont like the poly clay much personally though.
Re: clay bar
« Reply #4 on: March 07, 2011, 11:15:02 pm »
This ones for VC.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: clay bar
« Reply #5 on: March 07, 2011, 11:27:09 pm »
 :chicken: :chicken:
Ian. I worry about you sometimes  :laugh:
Offline SimonBash
  • -Given: 22
Re: clay bar
« Reply #6 on: March 07, 2011, 11:30:02 pm »
 :scared: :signLOL:
Re: clay bar
« Reply #7 on: March 07, 2011, 11:46:11 pm »
Only sometimes  :grin:
Re: clay bar
« Reply #8 on: March 08, 2011, 09:55:20 am »
beat me to it hedge  :signLOL:
Offline critter
Re: clay bar
« Reply #9 on: March 08, 2011, 10:14:17 pm »
Thanks for letting us know, il leave it till the summer,just for the record it was a megs bar and used the autoglym lube.
Offline SimonBash
  • -Given: 22
Re: clay bar
« Reply #10 on: March 08, 2011, 10:37:03 pm »
autoglym lube is their quick detial IIRC, if you've finished that get some meguiars last touch as I said pal, works out much cheaper and can use it for other stuff!
