Author Topic: Dash light ?  (Read 1792 times)
Offline stevw1
Dash light ?
« on: April 01, 2011, 09:39:55 pm »
Got a light on the dash, in the speedo, exclamation mark with a squiggle (if that makes sense)same as the SET button next to ESP on the ashtray front. I had a brake-light out when it came on,i have replaced the bulb but its still on ?
Steve
Re: Dash light ?
« Reply #1 on: April 01, 2011, 09:47:20 pm »
Is it the tyre pressure warning light?
Have you checked your tyre pressures? Once they are at the correct pressure, press and hold the set button until you hear a bong. You may have a puncture.
Offline stevw1
Re: Dash light ?
« Reply #2 on: April 01, 2011, 11:30:43 pm »
 :surprised: WOW !
Ive been driving a MK4 for 6yrs, only had the MK5 a few days its taking some getting used to. It has so many tricks n toys in a good way though.
Thanks for the reply will be checking ASAP.  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Dash light ?
« Reply #3 on: April 02, 2011, 07:57:20 am »
if all pressures are ok, press the (!) SET button till you hear a beep.
Cluster and Key coding
Location Great Yarmouth
Offline big al
Re: Dash light ?
« Reply #4 on: April 02, 2011, 11:45:50 am »
Should say what it is in your service book mate.
I had one come on the other day and had to pull over to find out what it was, turned out it was just the indicator LEd broken.
Offline stevw1
Re: Dash light ?
« Reply #5 on: April 02, 2011, 03:53:31 pm »
All sorted now.
Cheers Guys  :happy2:
