Author Topic: Best suspension mods?  (Read 17673 times)
Offline RussZS
  • -Given: 88
« on: April 27, 2011, 02:49:20 pm »
Coming from a Megane R26, I found the Golf on its test drive to have a fair bit of understeer, body roll and less overall grip than my Megane has.
I'm looking to address this as much as possible before going after big power, so what's the best stuff to go for?
Ideally within a £1000 budget.
I was thinking:
- KW V1's
- WALK
- ARB's
Am I along the right lines?  Anything else I should look at instead?
Russ.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Best suspension mods?
« Reply #1 on: April 27, 2011, 02:59:43 pm »
That's on the right track, i and a lot of others have chosen to just replace the rear ARB, which will help a lot in reducing understeer.  :drinking:
Over the top mod list ;o)
Offline RussZS
  • -Given: 88
« Reply #2 on: April 27, 2011, 03:02:44 pm »
Thank you :)
Is there anything else worth changing?  Are the KW's a good choice?  I'm not fussed about going mega low, just a bit lower and decent quality/handling
Offline keano
  • -Given: 79
« Reply #3 on: April 27, 2011, 07:54:34 pm »
Don't forget your brakes Russ. Standard ones are scary with power upgrades!  :driver: :driver:
« Reply #4 on: April 27, 2011, 09:09:15 pm »
I had Eibach coilovers on my old ED30, which use the KW V1 dampers. I got through two sets of dampers in less than 2 years. Personally I wouldn't have Eibach's again, so the same would be said of the KW's for me. :smiley:
I swapped to Bilstein PSS10's and they were much better. Cannot say if other Bilsteins would have the same resilience to my driving :laugh: but there you go. :wink:
  • -Given: 243
  • -Receive: 155
« Reply #5 on: April 27, 2011, 09:22:40 pm »
I must say i have the KW V3 and have run them for 2 years now, they are not bad, but the minute i get the chance to get Bilstein PSS10, i won't hesitate to get them on my car.
« Reply #6 on: April 27, 2011, 09:29:54 pm »
Dont forget to add a decent set of tyres too... they make 'night and day' difference in terms of understeer.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: April 27, 2011, 09:36:36 pm »
A UNIBrace is on my list of suspension mods!
Dom
Diesel Daily Hack.
Offline drsilviuro
« Reply #8 on: April 27, 2011, 09:51:53 pm »
TT suspension arms are the best mod IMO. They add negative camber to front wheel and reduces understeer.
Offline GNJ_Motorsport
  • -Receive: 20
    • GNJ Motorsport
« Reply #9 on: April 30, 2011, 06:29:19 pm »
Plans sound about right. As said though have a look at brakes if your going to up the power  :happy2:
0% Interest Free Finance Available On All Parts NOW
www.gnjmotorsport.com
info@gnjmotorsport.com  -  01254 883345
Facebook  -  Instagram
Offline RussZS
  • -Given: 88
« Reply #10 on: May 24, 2011, 03:18:49 pm »
How much are TT suspension arms please and where do I get them from?
Russ
Offline Carrera2RS
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #12 on: May 25, 2011, 12:45:28 pm »
Nice to see you making yourself at home here Russ!!  :happy2:
#1493
Offline RussZS
  • -Given: 88
« Reply #13 on: May 25, 2011, 12:46:58 pm »
Hello Luke :)
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: May 25, 2011, 01:12:23 pm »
rear ARB, WALK, TT lower control arms, uprated pads, THS engine mounts and then you'll have a superior handling car in everyway but with zero change in the day to day driving comfort.
Whiteline Rear ARB £150
TT lower control arms £350
Pads £100
engine mounts £240
leaving you around £150 for fitting
Coilovers are the best part of £750+ for the cheapo bottom end KWs. then add you arb and you already creeping over the 1k region with fitting costs and less to show for it
