Author Topic: Chewing gum  (Read 1710 times)
Offline nads1_uk
Chewing gum
« on: May 29, 2011, 01:04:37 am »
This might not be the right section but someone has brought chewing gum into my car on the passenger side mat.  Is there a product I can get from say halfords to get rid of it?  I'm wondering if I can buy some kind of freezer spray that will then make it easier to remove.
Andy
« Last Edit: May 29, 2011, 08:55:42 am by nads1_uk »
GTIStevie
Re: Chewing gum
« Reply #1 on: May 29, 2011, 04:22:36 am »
Try lighter fuel the stuff used to fill zippo lighters, my mum used to use it all the time for my school trousers.
Just apply a small amount then leave it for 15min then try removing gum, would suggest washin mat afterwards if u use this..
Re: Chewing gum
« Reply #2 on: May 29, 2011, 08:57:54 am »
Sticky stuff remover?
Autoglym intensive tar remover should dissolve.
Alternatively stick in the freezer and smash gum into pieces with you can then scrape off.
Re: Chewing gum
« Reply #3 on: May 29, 2011, 10:58:41 am »
I would imagine something like Tardis would break it down too.....
Re: Chewing gum
« Reply #4 on: May 29, 2011, 02:42:05 pm »
Tardis would be excellent but unfortunately halfrauds don't stock it.
Offline nads1_uk
Re: Chewing gum
« Reply #5 on: May 29, 2011, 05:38:30 pm »
Cheers for the help fellas.  I got some 'sticky stuff remover' from halfrauds worked a treat all gum now gone!
Andy
Offline suave
  • -Given: 31
Re: Chewing gum
« Reply #6 on: May 31, 2011, 01:12:08 pm »
All you have to do is rub the gum with an ice cube (or two depending on British summer).
It becomes hard and simply picks off your matt.
