Author Topic: Tfsi Mikes Money Pit :: AKS built Cupra :: TTE420 :: Rtech Tuned  (Read 1053261 times)
Offline OLLIE_JETTA_MK5
Re: Tfsi Mikes Money Pit :: Stage II+ Cupra **Mini update P20 pics**
« Reply #315 on: November 08, 2011, 02:00:42 pm »
i like this flocking stuff , but it would do my nut in all the bits that stick to it lol ! looks sweet mate
Dubbin it since 2006
« Reply #316 on: November 08, 2011, 08:22:20 pm »
Bought charcoal cabin / pollen filter this morning, 2min job :)
Old one was minging!  All that crap / dried leaves etc fell out the old filter!
New
« Reply #317 on: November 10, 2011, 08:17:53 pm »
Going to be a super slow drive home from the hospital tommorow!
Alot of bits lined up, its just finding the time!
Offline b9rgo1234
« Reply #318 on: November 12, 2011, 09:36:39 pm »
Hi Mike, Your car is looking really good  :happy2:
I sent you a PM on SCN bout the space savers, all 16"s im afraid. I got the LEDs ordered for the climate panel, thanks very much you your help  :happy2:
« Reply #319 on: November 12, 2011, 09:44:14 pm »
Not a proble mate, thanks for looking.
Cheers for the comments.
Climate panel is honestly one of my favorite mods or at least one I continue to appreciate :)
Offline damoegan
« Reply #320 on: November 12, 2011, 09:49:56 pm »
Mike, if you find some suitable winter wheel solution keep me informed  :happy2:
Offline b9rgo1234
« Reply #321 on: November 12, 2011, 09:52:08 pm »
I'll keep an eye open for you if your not in too much of a hurry for them  :happy2:
Did you ever change your tailgate struts from the fabia's?
I bought a pair from StrutsDirect, 520nm the same size as the standard leon struts but they dont lift it.
i was going to try the fabias next.
« Reply #322 on: November 12, 2011, 09:55:26 pm »
You're kidding!  I sold the fabia struts and I was goin to order from struts direct on payday.
The fabia ones were fine but not long enough.
Can I ask if you're using the sirrocco bumpers as they give the initial 'push'
Offline damoegan
« Reply #323 on: November 12, 2011, 09:59:29 pm »
JUst gona live with what I've got for this year, just planning for next winter realy  :smiley:
Mike, thats a bummer dude  :sad1:
« Reply #324 on: November 12, 2011, 10:04:02 pm »
Not in a rush mate no, thanks!  :happy2:
Offline b9rgo1234
« Reply #325 on: November 13, 2011, 11:27:48 am »
Hi Mike, sorry for not getting back to you last night.
Yea I "borrowed" a set of rocco bumpers from a car at work. I might order a new set and see if they work.
I have bootlid spoiler on my car, which will add an extra bit weight. That might be part of the problem.
« Reply #326 on: November 13, 2011, 12:00:07 pm »
No probs.
Because the spoiler is next to the hinge I don't think it will effect it.
What adjustments did you make to the bumpers, I must say with Rocco bumpers only my boot 'popped' just enough to get your fingers under.  It made me think they had a fair bit of push.
Sorry to sound daft, I'm not trying to insult your intelligence at all but have you adjusted the coding with vcds?
Just want to be sure before I spend £50 on struts!
Thanks for the reply!
Offline b9rgo1234
« Reply #327 on: November 13, 2011, 12:11:12 pm »
There is a hole in the middle of the bumper for an allen key, loosen the screw inside then fully compress it and retighten.
Yea I coded it with vagcom to fully unlock/open.
It only needs a little more kick when opening, maybe 5-10mm and it would lift itself. It works if I park one side on the kerb  :laugh:
« Reply #328 on: November 13, 2011, 12:14:13 pm »
I know, I've adjusted the bumpers lol.
Oh last thing do you have one or a pair of struts?
Offline b9rgo1234
« Reply #329 on: November 13, 2011, 12:22:43 pm »
Yea I got a pair
Order Cost: £51.20
  2 x Fixed Force Gas Strut - F-SD02-200
  - [4] Rod End Bracket: No Rod End Bracket Required
  - [5] Tube End Bracket: No Tube End Bracket Required
  - [3] Tube End Fitting: Steel Ball - SBJ7
  - [2] Rod End Fitting: Steel Ball - SBJ7
They are 520nm each. It takes a bit bloody effort to close the boot once its open let me tell you  :happy2:
