Author Topic: Dials?  (Read 6107 times)
Offline Johnny_tro
Dials?
« on: September 01, 2011, 09:01:38 pm »
Question........below are two tyes. Standard and the so called GTI/R32 style with deep dials and nice surrounds. Is this just a face plate? i.e if you have a highline unit which looks like pic 1....can you keep it and put the surround R32 style over the standard clocks?
'VANDALISED' MK5 GT :( - RNS510 H, Bluetooth Armrest, MDI, 50gb hard drive, I can't park  sensors, Cruise Control, Highline Display, MFSW, Heated Seats, Remote Aux Heating System (Heats and Vents) Winter Pack, Heated & Folding Mirrors, Puddle Lights, Xenons, Headlamp Washers, Heated Washers, Auto lights and wipers, LED's, GTI brakes,, black R32 roof lining, Scirocco Rear View, Rear Footwell Lights
Offline vRS_Pagey
  • -Receive: 59
Re: Dials?
« Reply #1 on: September 01, 2011, 09:05:09 pm »
I would say they are completely different clusters, besides that they will be a sealed unit and I certainly wouldn't consider breakin that seal to change the dial surrounds, any dust or muck in there and they will look carp.
Offline Johnny_tro
Re: Dials?
« Reply #2 on: September 01, 2011, 09:07:51 pm »
Mmm know whay your saying, would be a fiddly job.
Just wondered if anyone had done this? ££ to replace a highline to a r32 style highline just for a look....but do have an appeal about them
Offline Kalpsn2000
  • -Receive: 56
Re: Dials?
« Reply #3 on: September 02, 2011, 02:35:10 pm »
They definitely look sexier :happy2:
My old man has a TDI and before I got my GTI I thought the dials looked nice. Then got my GTI and after driving his TDI again I was thinking damn those dials look plain and unsexy :grin:
Offline vRS_Pagey
  • -Receive: 59
Re: Dials?
« Reply #4 on: September 02, 2011, 02:44:29 pm »
Well done, as he needed convincing...... :signLOL:
Re: Dials?
« Reply #5 on: September 02, 2011, 03:21:31 pm »
pic 1 is midline and has been done by someone on the forum.
Offline Johnny_tro
Re: Dials?
« Reply #6 on: September 02, 2011, 05:26:12 pm »
These are examples guys.....and a standard highline - but would like the GTI look.......can this be done without me having the spend £200 on some new dials :(
Offline mortygttdi
  • -Receive: 146
Re: Dials?
« Reply #7 on: September 05, 2011, 12:14:46 am »
What reg is the new car? if its under a 56 plate then I have an offer you may not want to refuse?
Darren
Offline Johnny_tro
Re: Dials?
« Reply #8 on: September 05, 2011, 12:15:24 am »
car is 2004-2005 - collecting wednesday
« Last Edit: September 05, 2011, 12:38:24 am by Johnny_tro »
Offline dalco
Re: Dials?
« Reply #9 on: September 05, 2011, 09:35:25 am »
Darren
Whats the Offer??
I have a 1.9D very basic Golf, The cluster looks like the Pic 1 above, The top half of the centre display doesn't do anything, the lower section just has normal old fashioned 8 digit lettering if that makes sense?
Can the clocks be upgraded to the higher end ones??
Offline Johnny_tro
Re: Dials?
« Reply #10 on: September 05, 2011, 11:25:53 am »
Clock can be upgraded buddy, believe you need to budgets £150-£200 give or take.
You need to find the right clocks to match your car then you need some one to plug the car in and code it. Search replacing highline or replacing clocks there is a full thread on it.
I can only give you the basics.....no expert, but thats it in a nut shell.
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Dials?
« Reply #11 on: September 05, 2011, 11:42:48 am »
I think what you were trying to say in the original post is can you get away with fitting the GTI faceplate on to a standard highline cluster?  If I'm right then I think you will be able too, but you will need to get hold of the face plate the backing plate and the dials and needles, you would also need to change the cluster bits to give you things like the lit needles without the lights on as per GTI/R32.
My build thread and cluster destruction might help you out, you would also need the plastic backing for a highline cluster or you would need to dremel the plastic divide that you have on a midline cluster out of the way.
http://www.mk5golfgti.co.uk/forum/index.php/topic,30002.15.html
Offline Johnny_tro
Re: Dials?
« Reply #12 on: September 05, 2011, 11:58:35 am »
Basically.....I have a std highline, would like the look of the GTI highline.
As per your comment.......(if I have this correct) I would need
- Front plate
- Back plate
- Dials
- Needles
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Dials?
« Reply #13 on: September 05, 2011, 12:13:02 pm »
you would need the whole front piece from a GTI or R32 clock, which is made up of the front part that you see a rear part that is midline or highline specific plus all the glass panels, plus you would need the GTI needles and the dial cards for all 4 dials rpm speedo fuel and water temp.
You would basically be better off buying a broken cluster in good cosmetic condition and stripping and moving across, I have never done this but I suspect its as simple as that as all the impulses are electronic so the speed and rpm values arent important.
Offline Johnny_tro
Re: Dials?
« Reply #14 on: September 05, 2011, 12:21:44 pm »
that was I assumed. I must be a basic simple cosmetic update - all the digital side on things must be the same......
