All Things Mk5 > Performance Modifications
Nearly finished, thoughts on final tweeks !
Poppa Dom:
--- Quote from: Tfsi_Mike on September 04, 2011, 04:08:12 pm ---Thanks I changed the spring on my forge but may try a revision DV to see if there is a difference
What kind of pressures are you getting & what state of tune? :happy2:
--- End quote ---
1.68 bar, ST2+ on ko4 :happy2:
Tfsi_Mike:
--- Quote from: DomT on September 04, 2011, 04:18:28 pm ---
--- End quote ---
--- End quote ---
If you're happy at that I'd willingly try one to see the difference...
Carrera2RS:
--- Quote from: fab5freddy on September 04, 2011, 10:50:28 am ---@ OP
What was your final Geometry settings?
I have the TT arms & ball joints going on this week, along with the bumpsteer kit
I'm lowered on 30mm H&R springs, Bilstein B8's and running 7.5J 18 OEM monzas with WALK also
Any help would be much apperciated as i've read all previous threads on this subject but am none the wiser :stupid:
--- End quote ---
This thread might help http://www.mk5golfgti.co.uk/forum/index.php/topic,28835.0.html
I currently run 3-5mm higher but this was the base settings :
Ride height 338 mm
Camber L -2 deg 10 mins, R -2 Deg 0 mins
Toe L - 6mins, R - 6mins (toe out)
Caster L 8 deg 13 mins, R 8 deg 14 mins
SAI L 16 deg 36 mins, R 16 deg 21 mins
Bilstein PSS10 setting 3/10
Neuspeed 25mm bar full soft
WALK
Tyre pressure 35 psi after a 20 minute normal journey (32.5 cold)
Tyre Pirelli P Zero 225/18 92Y XL MO
Rear
Ride height 324mm
Camber L -1 deg 37 mins, R -1 deg 30 mins
Toe L 6 mins, R 7 mins (toe in)
Bilstein PSS10 setting 4/10
Neuspeed 25mm full hard
Tyre pressure 33.5 psi after a 20 minute normal journey (31.5 cold)
Carrera2RS:
--- Quote from: DomT on September 04, 2011, 08:55:20 am ---IMHO I would be running the latest revision DV over the Forge one. :happy2:
--- End quote ---
Dom, hi
I'll check the one that came off, a late 08 Pirelli might have a late version ?
Poppa Dom:
Possibly - will be obvious once you see it as ETKA PN clearly visible :happy2:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
