Author Topic: How to retro fit cruise control. Comprehensive guide  (Read 181359 times)
kisyov
Re: How to retro fit cruise control. Comprehensive guide
« Reply #30 on: March 21, 2019, 04:48:17 pm »
Hello friends, I need help. I have VW Caddy Maxi 2009 /same as golf mk5/, after retrofitting cruise control and MFSW , horn stop working and the buttons of SW Not working. I change my control module from mid line to highline /from 1K0-953-549-CQ to 1K0-953-549-CF /. From Ross-Tech website I saw that my Slip Ring is Type 2. I think, I did everything right, but only cruise control working, no buttons and no horn.
Parts I use.
1Q0 419 091 KUSZ – Steering Wheel / 17.11.2007 /
1K0 971 584 N – airbag harness / original harness from my not MFSW is same without N /
2k0 880 201 L 10QB -  Airbag from my original SW
1k0 959 538 F – MFSW buttons
1P0 959 542 – MFSW control unit
1K0 953 549 CF – Control module
1K0 953 513 G – Cruise control stalk
Wipers stalk I didn’t change, it is with trip button.
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000534
   Shop #: WSC 01357 011 00200
   VCID: 78FF0E6B0B2690DEAC3-802D
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
            004 - No Signal/Communication
I thought that My SLIP RING NOT working, after I put my old airbag harness from non MFSW and recoding the Control Module,  horn start working and cruise control, too. So my SLIPRING is OK.
So what is wrong , where is my mistake? I want my MFSW to work. I this to change airbag harness, please suggest model.
Offline martinatfc
« Reply #31 on: April 07, 2019, 07:27:36 pm »
Can someone do mine for me?
I have a 2005 Golf GTI Mk5.
Cash up for grabs obviously.
My DIY skills are useless.  :fighting2:
I'm based in Farnham, Surrey or Aldershot, Hampshire.
Offline Octoparrot
  • -Receive: 104
« Reply #32 on: April 07, 2019, 09:30:45 pm »
Do you know if you have the extra wire fitted?
Offline kevster996
« Reply #33 on: May 04, 2019, 12:55:03 pm »
I just updated my stalk to cruise control and updated the steering wheel control module to the CH version (new one off ebay). I have fitted an MFSW now but not coded yet. Now when I start up the right hand indicator goes all the time and using the stalk makes no difference?
I need to do the power steering reset as Ive lost this now too? My car is a 55 tdi 4motion - I wonder if I need to get a different slip ring? I'll check the part number. Bit dangerous to drive with indicators turning right all the time!
Parts I have:
- Cruise Control Indicator Stalk Arm OEM 1K0 953 513 F (wrong one?) (old one 1K0 953 513)
- slip ring 1K0 959 653 C (should ok with steering wheel module?)
- new steering wheel control module 1K0 953 549 CH off ebay (should work with my slip ring)
I need to wire in the extra wire to the ecu for CC - its only half done
Ive put the old stalk back on for now and its sorted the indicator issue...
« Last Edit: May 05, 2019, 12:21:01 pm by kevster996 »
Golf 5 2005, 2.0 TDI 4motion, remapped to 175bhp, lowered on eibach springs, GTI front end, GTI half leather interior
Offline ljc19630
« Reply #34 on: May 08, 2019, 06:50:00 pm »
Niceeee
Offline kevster996
« Reply #35 on: May 09, 2019, 07:01:33 pm »
Parts I use.
   Coding: 0000534
1 Fault Found:
did you fix this yet? i have similar problems on my 2005 tdi 2.0 - I need to get VCDS on it I think. I have CH module not not CF like yours and a midline display. I dont have power steering either right now since I changed the module! I have found a local guy who can have a look - he is about £60 an hour but can prob do lots in one hour... I hope I dont need a different module.
Offline GTXcess
« Reply #36 on: February 23, 2026, 11:01:35 am »
Having my read this morning excellent guide, and various YouTube videos I’ve now had two goes at this with no luck and would welcome some advice.
My 2008 GTI now has the right CC stalks, I’ve coded through VCDS and can see that the stalks are registering inputs by looking at the measuring blocks. But nothing is producing lights on the dash or CC actions. The control module is the midline BC variant and as a 2008 car should have wiring installed.
Before I start buying any more parts to throw at it, any suggestions as to where I’m going wrong?
Offline mjmallia
  • -Receive: 60
« Reply #37 on: February 26, 2026, 10:59:50 am »
I would double check there is a wire and not make the assumption, as the car might see the stalk but it is not being received by the ECU.
I sell the wire if needed, as if everything else is fitted and coded that is all  :happy2:
Mike
South Coast
