Author Topic: GT 170 Suspension comparison  (Read 11140 times)
Offline Trekmeister
  • Golf GT 140
« on: January 07, 2012, 06:04:24 pm »
I have a MK5 GT TDI 140 and wanted to know if anyone knows the difference between this and the GT 170 suspension setup I.E ride height, dampers etc. Does the 170 have a lower ride height than the 140? If so I guess it would be a matter of buying the 170 springs and replacing them in order to keep it OEM?
Brad
Offline mortygttdi
  • -Receive: 146
Re: GT 170 Suspension comparison
« Reply #1 on: January 07, 2012, 06:08:25 pm »
Exactly the same suspension mate, the only difference on some of them is the GT SPORT came with a 15mm lower ride height i.e like the GTI.
Darren
Offline Trekmeister
  • Golf GT 140
« Reply #2 on: January 07, 2012, 06:41:38 pm »
I wanted to lower the suspension but not by too much so it sits lower but not by too much, not sure if I have the sport version or not, its not on log book but it has 17" bbs alloys GTI style front grille, leather steering wheel. Any way to tell or would it be on log book only?
« Last Edit: January 07, 2012, 07:52:46 pm by Trekmeister »
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #3 on: January 08, 2012, 12:39:29 pm »
What reg is it? Someone put a list on the site somewhere describing all the different GT differences. No idea where though  :rolleye: Il have a look!
Offline Trekmeister
  • Golf GT 140
Re: Re: GT 170 Suspension comparison
« Reply #4 on: January 09, 2012, 02:22:25 pm »
Its on a 56 plate
Sent from my GT-I9100 using Tapatalk
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #5 on: January 09, 2012, 08:05:01 pm »
No idea where i saw the list with the different mods. The GT Sports with the dark headlights came with lowered suspension as Darren said.
Here is mine standard height (GT Sport so should be -15mm):
Lowered on springs so roughly between 30 - 40mm i guess?:
Offline Trekmeister
  • Golf GT 140
« Reply #6 on: January 09, 2012, 08:07:41 pm »
I think mine are standard also, was thinking of putting Eiback sportslines on with a 20mm drop.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #7 on: January 09, 2012, 08:43:23 pm »
All GT Sport are lowered by 15 mm, but not as stiff as a GTI.
170 BHP GTs may have slightly different spring becaus of more (front) weight
compared to the 140 BHP.
Look for the Volkswagen Driver Gear springs made by Eibach. These offer
the slightest lowering similar to the pictures shown.  :happy2:
ps:
I'd swap the 288 mm discs for the 312 mm ones  :wink:
"You get what you pay for."
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: January 09, 2012, 09:19:51 pm »
ps:
The 170tdi  BMN engine is the exact same engine has the 140tdi BKD its just the turbo/manifold, injectors and ecu that are different so no weight difference. Same block and cylinder head.
Offline Bikerz
« Reply #9 on: January 09, 2012, 10:46:57 pm »
My 170 GT TDI is lower then that pic of the 140 Joe posted, Infact mine looks as low as his on teh 35mm springs
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #10 on: January 10, 2012, 12:00:16 am »
I know the differences between both 2.0 TDI engines, but VW specifies
different weights and fwik they also use different springs (refer to ETKA).
Driver Gear springs work well though and are very popular in the US,
but I'd recommend to use lowering springs with Bilstein dampers or at least
GTI dampers.
Offline Trekmeister
  • Golf GT 140
« Reply #11 on: January 10, 2012, 06:25:48 am »
Do you know where I could pick some VW driver springs up because your car has the exact lowered look which I am after I.E link, part number etc
