Author Topic: Dressing Wheels Arches - CG Bare Bones  (Read 8016 times)
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: Dressing Wheels Arches - CG Bare Bones
« Reply #15 on: April 17, 2012, 10:44:12 am »
As my car isn't lowered yet, so when washed the arches are discoloured, so they're light grey, instead of a deep black. The CG Bare Bones gave a deep glossy finish, but I guess once I lower the car this won't be a massive issue.
Besides guys, the devil is in the detail :evilgrin:
« Reply #16 on: April 17, 2012, 10:47:58 am »
Does the CG Bare Bones glossy finish serve to reduce the crap sticking to it?
From that point of view I'd be interested in doing it.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #17 on: April 17, 2012, 10:52:30 am »
Think yourself lucky you have plastic wheel arch liners. The Octavia has a fabric soundproofing liner which is a right royal pain in the arse to keep clean. Even scrubbing with a brush and using the PW with the wheels removed it still looks filthy.
The only plastic bit in the wheel arch is as you can see in the pic below. The remainder is that Fabric which goes all the way round to the sill on the opposite side. Obviously you could remove it but that kind of defeats the object of it.
Offline craigy123
  • -Receive: 24
PM for details
  • -Given: 32
  • -Receive: 78
« Reply #19 on: April 17, 2012, 11:12:03 am »
My rear arch liners are completely fabric, and you're right, they are a total pain to keep clean.
Offline DanGB
  • Different
« Reply #20 on: April 17, 2012, 11:27:32 am »
I keep toying with the idea of trying Aerospace 303 - just put off by the price :ashamed:
I have that and put off the price as its good to use lots, so autoglym bumper and rubber spray  is a decent alternative.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
  • -Given: 32
  • -Receive: 78
« Reply #21 on: April 17, 2012, 11:39:10 am »
Not in my experience...
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #22 on: April 17, 2012, 11:55:01 am »
I am considering removing it and covering the wheel arch with sound deadening before replacing the plastic liner part only.
« Reply #23 on: April 17, 2012, 02:56:25 pm »
As above, doing arches is part of the "detail" in detailing IMO. If you were gonna do the car properly, I'd do it as part of it. For me, I'd only bother if it were pre-show eg night before. Otherwise it's 2-3 times a year max.
Durability is how long the product lasts in terms of time, not how much you use. Or did you have to keep topping it up?
  • -Given: 32
  • -Receive: 78
« Reply #24 on: April 17, 2012, 04:35:55 pm »
Sorry, I wasn't meant to infer that I didn't think it was durable because I had to use lots of the product, simply that I had to use a lot and that the final effect didn't last too long.
Offline keith
« Reply #25 on: April 17, 2012, 09:15:46 pm »
If you can get the wheels off or can get access fairly easy then you can try autosmart trim ultra - linseed based dressing lasts ages if applied to a clean plastic surface(exterior only) also worth a mention is Valetpro's Dionysus trim glitz along the same lines as trim ultra. Both need time to dry/cure. these aren't vogue products but are def worthwhile.
