Author Topic: Just had the GIAC DSG software fitted!!!  (Read 31068 times)
« on: May 15, 2009, 05:55:20 pm »
What can I say....bloody great bit of software that makes the DSG what it should have been from the factory
7k+ shifting ftw.
Faster shifts up AND down the box
Smoother shifting up and down the box (didn't think this was possible)
Better "blipping" noise from the zorst
Manual mode is now a manual (but if you push it continuously it will push through the rev limite to the next gear if you want it to)
Faster set off from a standstill
Better torque handling capability
Torque limiter relaxed in 1st and second gears
60mph is now possible in second and 90+ in 3rd
It now releases the full rpm power potential of the K04, so no more RR days with the box killing the power just over 6200rpm
Option of launching with up to 3,700 revs with launch control (and 4,500 for the R32 boys, which must be handy )
There are other companies who are developing DSG remaps, HPA, Revo etc, but they will find it hard to better unless you are able to customise the settings yourself with a handheld programmer
Even though it is damp out I can tell the difference. I reckon it is good for probably 0.3 to 0.4 off the standing quarter :jumping:
Honestly, if you have a DSG and want to get the best from it, a DSG remap (whoever you choose to do it) is an absolute must have
Roll on my Quaife arriving now to knock a few more portions off the QTR mile. :evilgrin:
Offline WhiteGTI
  • F-A-S-T
Re: Just had the GIAC DSG software fitted!!!
« Reply #1 on: May 15, 2009, 05:57:08 pm »
If this had been around when I was speccing my GTI, then I would have definitely gone for DSG!!
Very exciting modification! You must take me for a spin in your car one day John so that I can feel it!
2006 E46 BMW M3 - 343hp
« Reply #2 on: May 15, 2009, 05:58:58 pm »
Roger that :happy2:
Offline 182_blue
  • -Receive: 54
« Reply #3 on: May 15, 2009, 06:03:48 pm »
wherein the car/ how do they program the DSG box
Offline neg
  • gone old skool
« Reply #4 on: May 15, 2009, 07:05:04 pm »
WOW, look forward to seeing and feeling this!
Your on the stock clutch still then - no new clutch packs or anything yet?  Sorry cant remember how far you got with it
Phil Mcavity
« Reply #5 on: May 15, 2009, 07:14:52 pm »
 :drinking: cheerio Mr Clutch  :signLOL:
You must resist the temptation to use Mr launch control John!!.
Sounds awesome Mate, your car was fast enough before, let alone this mod!!.
LSD next..... . Test drive please!!, ill form an orderly cue  :wink:
Offline neg
  • gone old skool
« Reply #6 on: May 15, 2009, 07:25:11 pm »
It'll be like a group buy - tickets numbers
1.neg  :laugh:
I have also decided, John you have to much spare cash  :wink:
Phil Mcavity
« Reply #7 on: May 15, 2009, 07:27:16 pm »
1.neg
2. Phil and Brown paper Bag :signLOL:
« Reply #8 on: May 15, 2009, 07:27:40 pm »
It is programmed through the OBD port like the ECU tuning. Mine took a while to do as they didn't have my code for the box and so had to refer it to the USA which took a couple of days (USA west coast time differential doesn't help!). Once they had the code it literally took ten minutes to hook up and download the map into the mechatronics control unit. It doesn't affect your ECU map at all (you can have any engine map on the car...REVO, CC, GIAC, APR etc) and as long as your engine map has a higher rev limiter than the GIAC DSG map then it is fine. If you have a lower engine rev limiter (ie stock) you can still have the DSG remap modified to allow you to use it. :smiley:
« Reply #9 on: May 15, 2009, 07:31:12 pm »
Yes, I'm still on the stock clutch. The GIAC site quote that the clutches are uprated to handle 500nm safely by the remap (don't ask me quite how, but I understand it is something to do with the oil pressure giving a higher clamping pressure on the clutch plates to reduce slip and give a more positive engagement).
All I know is that the car is more responsive and definitely more sprightly than before :evilgrin:
« Reply #10 on: May 15, 2009, 07:36:17 pm »
1.neg  :laugh:
 :signLOL:
1.neg
 :signLOL:
You two crack me up :grin: The missis just asked me what I'm laughing at
Offline Aparoon
« Reply #11 on: May 15, 2009, 07:45:07 pm »
Sounds very good mate, i am very tempted by this but am concerned about warranty if there was to be a fault with the dsg  :scared:
Edition 30 DSG, Revo 2+,BSH Intake, Autotech hpfp, Blueflame TBE,  Eibach Sportlines, Speedline Turini's GONE
« Reply #12 on: May 15, 2009, 07:55:11 pm »
Mine car is 2yrs and 2 months old, but I probably invalidated the warranty in the first six months with what has gone on the car.
I was always going to modify my car and so the warranty was of little concern to me from the offset. Once I'd had the car a few months and it was all running fine with the small niggles sorted by VW, I just set about the car and didn't worry about the warranty at all. If you are worried about the car's warranty then you do need to seriously think before modifying :smiley:
« Reply #13 on: May 15, 2009, 07:58:22 pm »
Can this be done on a car thats not remapped John?  :chicken:
« Reply #14 on: May 15, 2009, 08:14:02 pm »
Yes, I asked this at the time and they can do a modified map for OEM stock customers too. All they would have to do is ensure the engine limiter is higher than the GIAC DSG limiter :happy2:
