Author Topic: Coolent leak  (Read 2190 times)
Offline plod86
Coolent leak
« on: May 23, 2009, 10:18:14 pm »
I have noticed that my car has started to work its way through rather a lot of engine coolent. On a closer inspection i can see that there is coolent dripping on to the gearbox. Im not sure where the leak is coming from???? If anyone has any ideas that would be great!
Pete
Offline VW Racing
    • VWR Racingline
Re: Coolent leak
« Reply #1 on: May 23, 2009, 10:23:53 pm »
Manual or DSG?
If Manual there is a stupid conection on the side of the block just above the gearbox with a plastic "u" clip i have seen those work loose.
If its DSG there are two cooler pipes going the the "KTM" labled cooler unit, one also has a "u" clip holding a comection together. i would start with checking they havent worked loose.
Mark
Re: Coolent leak
« Reply #2 on: May 24, 2009, 09:11:20 am »
Mark
....Is that the same connection you thought might have once been (or indeed was) the cause of my coolant leak in the past, Mark?
Offline VW Racing
    • VWR Racingline
Re: Coolent leak
« Reply #3 on: May 24, 2009, 09:16:12 am »
HI Robin
Yep was thinking possibly the same thing, but without seeing exactly where the coolant stains are, just a guesstimate at the moment.
Mark
Re: Coolent leak
« Reply #4 on: May 24, 2009, 09:45:27 am »
Well, obviously the answer is for Pete (plod86) to reduce his engine movement (and potential stress on the coolant connection thingy on a modded car) by getting a dogbone engine mount :evilgrin: :evilgrin:. I can recommend one which VWR offer btw :grin: :wink:
[Really nice mod - Review to be posted soon] :smiley:
« Last Edit: May 24, 2009, 09:47:56 am by RedRobin »
Offline billyboy
  • Billy lar
Re: Coolent leak
« Reply #5 on: May 24, 2009, 10:15:31 am »
X2 with this, as your boys put mine right whilst doing the clutch,
billy
