Author Topic: Remap for GT TDI 140  (Read 3041 times)
Offline subzero
« on: July 04, 2012, 02:28:16 pm »
Had this for 4 months now just fitted a straight though cat back @ 2.25 bore and a jetex air filter.
now looking at remap but dont want smoke pouring out all the time, car runs very clean as is.
best suggestions ? based in cheltenham GL52
i noe forge is just up the road and i think they do revo maps they any good?
Offline Llew
  • -Given: 45
Re: Remap for GT TDI 140
« Reply #1 on: July 10, 2012, 02:01:39 am »
I have asked this question before this is the advice I was given which IMO is correct
1st decat
2nd upgrade breaks
3rd remap
From reading the reviews on here my preference is to go for an r tech remap
I hope this helps
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline jamadz
« Reply #2 on: July 21, 2012, 10:49:55 pm »
ive had a chipped uk remap for 3 years, runs fine with a little smoke now and again
Offline AndrewJB
  • die gelbe Baron
« Reply #3 on: July 21, 2012, 10:56:48 pm »
is it a CR or PD Engined car?
if its a CR, APR have just released new software for the CR
Offline DarkSideJohn
« Reply #4 on: July 21, 2012, 11:03:11 pm »
I have a GT TDI 140 myself
Couple of stupid questions coming up ;)
When people say upgrade the brakes , are we talking better discs and pads or going to a GTI 312mm set up ?
Is the GTI setup a straight bolt on ?
'04 GT TDI 140 | Remapped | Cold Air Intake | WALK | TBE
Offline jamadz
« Reply #5 on: July 22, 2012, 11:57:01 am »
changing the brakes was the first thing i did, you will need the calipers, carriers and discs from the GTI, you can normally get these second hand for under £100
Offline skard
  • -Receive: 245
« Reply #6 on: July 22, 2012, 12:01:19 pm »
On a tdi 140 the caliper itself is the same as a GTI/GT 170, thus you only technically need to change the pad carrier and discs.
The pad is still the same but better to change it with the new discs.
When I did it I changed it all as I didn't want red carriers with factory rusty calipers - was also a good excuse to DIY a brake fluid change.
« Reply #7 on: July 22, 2012, 12:08:28 pm »
Im quite shallow and quite fancy a set of red brakes :P
Guess ill have to keep a look out for a full set of Calipers and carriers then , discs and pads are quite easy to come by so they could wait.
