Author Topic: Which Clay Bar? (now with finished pics).  (Read 2941 times)
Offline mrbeck
« on: July 31, 2012, 08:39:25 pm »
Have finally decided to give my car a proper clean, after several months of neglect.  Got loads of crap stuck to the paintwork so I'm in need of a good (but not ridiculously expensive) clay bar to help with the removal process.  What would you all suggest is best, and where is best to buy it?  Thanks in advance!
« Last Edit: August 03, 2012, 10:43:58 pm by mrbeck »
2008 VW Golf GT Sport TSI 1.4 (170PS)
OEM + Cruise Control (Retrofit), R36 Omanyt 18" Alloys, R32 Rear Lights, VW Polo Stubby Aerial, VW Front & Rear Mud Guards, Team Heko Wind Deflectors, Dubmeister Pressed Plates, ABT Wolfsburg Plate Surrounds, Autoform Boot Liner.
Re: Which Clay Bar?
« Reply #1 on: July 31, 2012, 08:43:22 pm »
Best depends on what you need it for.
I would go with Bilt Hamber autoclay soft. Can break it into 4 portions and use one each time for the entire car. Uses water as lube though I still like to use Born Slippy clay lube.
Offline mrbeck
Re: Which Clay Bar?
« Reply #2 on: July 31, 2012, 08:55:29 pm »
Cheers for the advice stealthwolf.
Bilt Hamber Autoclay Soft and Dodo Juice Born Slippy Clay Lube now ordered.  Will post pics after its cleaned at the weekend!
Re: Which Clay Bar?
« Reply #3 on: July 31, 2012, 09:00:59 pm »
I'd also look at a tar remover eg tardis if you don't already have one. If you have large tar spots, you won't pull them off with the clay - you'll just push it around and cause damage!
What are you doing about polish and LSP?
Offline Grande_GTi
  • -Given: 41
Re: Which Clay Bar?
« Reply #4 on: August 01, 2012, 08:25:55 am »
Im another massive fan of bilt too
For the money its great value, and is also a great product to use, but u may want to work out weather u need the soft, medium or the super bad boy stuff
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Which Clay Bar?
« Reply #5 on: August 01, 2012, 09:21:46 am »
Whatever you use, make sure you warm it up before use and keep it warm, fold it on itself and use plenty of lube...
Diesel Daily Hack.
Offline mrbeck
Re: Which Clay Bar?
« Reply #6 on: August 03, 2012, 10:41:17 pm »
So the Bilt Hamber arrived this morning, and I set to work.  4 hours later, the clay bar was filthy, and these were the results.  Not a bad finish I thought, considering it was all done by hand...
And the beading ain't too bad either (there was no beading at all before I began)...
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Which Clay Bar? (now with finished pics).
« Reply #7 on: August 04, 2012, 07:25:25 am »
Looks good :smiley:. Can't beat a clean black car.
Offline mrbeck
« Reply #8 on: August 04, 2012, 08:56:50 am »
Unfortunately it never stays clean for long!
Offline phil1975
  • 2011 Gti
« Reply #9 on: August 04, 2012, 10:41:00 am »
Good work! bilt hammer is excellent.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #10 on: August 04, 2012, 02:00:42 pm »
...........i know mate mine's black also.
Offline Frenzy
  • -Receive: 29
« Reply #11 on: August 14, 2012, 11:06:04 pm »
Good work, but have you done anything else since like an additional wash, maybe a polish and a sealant / waxing? If not then all your work claying won't be for much...
Offline mrbeck
« Reply #12 on: August 15, 2012, 11:55:46 am »
Yeh, sorry.  I clayed it, rewashed it, then polished and waxed.  Just need to keep on top of it now!
Offline Frenzy
  • -Receive: 29
« Reply #13 on: August 17, 2012, 02:59:53 pm »
Thought you probably would have so I wasn't meaning to suggest you were a total noob, however it's always worth asking as you can then help out someone who may not be fully in the know  :happy2:
