Author Topic: Post T-Cut woes!  (Read 2551 times)
Offline Sharman
Post T-Cut woes!
« on: June 06, 2009, 02:48:24 pm »
I was driving down a country lane in my MK5 GTI, when some numpty coming the other way in a transit van cut the corner(picking his nose), forcing me to "brush" the edge. It wasn't until I got home that I noticed I had a full length scratch  :sad:. It had scratched the laquer mainly on the wing and passenger door. I T-cutted the worst of it out, then applied meguiars wax and P21 carnuba. It looked good, until it rained! It's left a slightly dull patch with tiny swirl marks. I have waxed again, but fear it may need some professional buffing/polishing work. I don't think(or hope) it needs any paint/spraying. Any recomendations of either a good valeter or specialist wax etc. I'm gutted and binned the T-cut! I'm from Chesterfield. Cheers
Offline 182_blue
  • -Receive: 54
Re: Post T-Cut woes!
« Reply #1 on: June 06, 2009, 02:50:22 pm »
what tcut did you use ?
Offline Sharman
« Reply #2 on: June 06, 2009, 04:01:41 pm »
One out of a pastic tube(toothpaste like), probably from wilko's. Think it said it was safe on my paintwork.
Offline chip20
  • -Given: 35
    • http://absolutevaletinguk.co.uk/
« Reply #3 on: June 06, 2009, 04:26:30 pm »
Hi.Sounds like it will buff back with a polishing machine.Shame i am in Bolton. I would have had a look and sorted it for you
« Last Edit: June 07, 2009, 09:41:52 am by chip20 »
Offline Sharman
« Reply #4 on: June 06, 2009, 05:11:12 pm »
Cheers anyway :happy2:. At least it seems that it may buff back, was totally gutted! I think I'll leave it to the professionals
Offline 182_blue
  • -Receive: 54
« Reply #5 on: June 06, 2009, 06:15:07 pm »
not sure what you bought but its probably left its own marks which makes it look dull, it possibly can be corrected without a machine with a lot of hard work though
these guides may help
http://www.detailingworld.co.uk/forum/showthread.php?t=105075
http://www.detailingworld.co.uk/forum/showthread.php?t=10656&highlight=hand+swirl+removal
Offline Jules86
  • -Receive: 46
    • Forumwars
« Reply #6 on: June 06, 2009, 07:23:42 pm »
I wouldnt use T-cut on an enemies car! You are better off with wire wool than T-Cut!
It will buff up but will require a machine  :wink:
Offline autoperfection.com
  • autoperfection.com
    • autoperfection shop
« Reply #7 on: June 08, 2009, 01:40:11 pm »
The T-cut has put marks into the paint as it is quite abrasive - think of it as a mild sand paper if you like..
You will be able to bring back the shine by hand.... by basically removing those fine scratch marks..... it will take some elbow grease mind, but you can do it no probs - as long as you use the right products.
If you need some small amounts of product to use just let us know and we can get some bits sent up to you :happy2:
Taryn and Jim
