Author Topic: Anyone in/near bristol with a Vag-Com ?  (Read 2391 times)
Offline true-blue
« on: June 13, 2009, 04:52:43 pm »
My Wife's A4 had classic coil pack breakdown, so I've been to Audi this morning for three new ones (only changed one about a month ago - so thought I'd just stick three new ones in) and the car now seems to be absolutely fine, the 'check engine' light has gone out on it's own, same as last time, but the EPC light has come on a couple of times ?  (doesn't stay on though)
Wanted to read the fault codes to see what's triggering the EPC Light now!
Cheers.  :smiley:
Octavia Vrs MKII - KO4, forge twintercooler, S3 Injectors, APR HPFP, RS4 FP Valve, Pipeworx 3'' DP and Sports cat, Piper non res exhuast, ITG Maxogen, Quaife Dif, sachs clutch kit, NQSBBBK with RS4-2 pads, H&R SS Coilovers with adjustable koni inserts.
Good for 328 BHP on JKM's rollers !!
Offline Mark_GTIV
Re: Anyone in/near bristol with a Vag-Com ?
« Reply #1 on: June 13, 2009, 04:57:28 pm »
Offline true-blue
« Reply #2 on: June 13, 2009, 05:37:44 pm »
Have a look at this list...
http://www.mk5golfgti.co.uk/forum/index.php?topic=120.0
Ok, so that's no one then and I can expect the post to be deleted  :scared:
Offline Mark_GTIV
« Reply #3 on: June 13, 2009, 06:00:31 pm »
Why would it be deleted?  :surprised: Perhaps someone has VCDS but hasn't registered in your area.
Offline celica
« Reply #4 on: June 15, 2009, 12:27:11 am »
i wouldn't mind knowing as looking to get a new spare key and so requires programming
MKV Golf DSG
  • -Receive: 453
« Reply #5 on: June 15, 2009, 09:31:38 am »
You'll need to go to your VW dealer to do the above.
Offline true-blue
« Reply #6 on: June 15, 2009, 12:36:31 pm »
Thanks Gent's,
had some help from Audisport.net, it was the Crankshaft timing sensor, common part to fail on the 1.8T.
 :smiley:
