Author Topic: PCV Failure?  (Read 2063 times)
Offline AlanEdition30
PCV Failure?
« on: October 06, 2012, 06:36:13 pm »
Done a 350 mile round trip to Birmingham from Norwich today and on the return journey the car has started to idle higher than it normally does. If you put it in d (dsg) the revs lower again, but when in park or neutral the revs rise again. Ive done a search and found a bit more information e.g faulty pcv.
Anybody else had this problem and if so, what sorted the problem?  :happy2:
Offline Leach76
Re: PCV Failure?
« Reply #1 on: October 08, 2012, 11:13:54 am »
Pretty common to be honest mate,try a new valve in it and they have also done a revised top breather for the head depending on what year your car is on it maybe peace of mind fitting one of these also as i think its only about £90 inc vat for the pair,its on the to do list for mine also
Phantom black S3,Giac stage1 & Evoms intake
Re: PCV Failure?
« Reply #2 on: October 08, 2012, 12:02:06 pm »
Yeah having done a few more searches its a common problem. I dont know whether to do it myself or book into local revo garage and get them to also change to the latest dv (revision g) and change the cam follower, as my car has now done 43k and its still on its original pcv, dv and cam follower.
I think these are all things ive read on the forum that should be changed periodically? Is this correct?
Re: PCV Failure?
« Reply #3 on: October 08, 2012, 12:11:30 pm »
As you have an Eddy (if your mechanically inclined) its an easy job to do yourself, both the DV and PCV are right at the front of the engine. Couple of torx screws and bobs your uncle. Removing the engine cover is the hardest bit IMO, right PITA. Would recommend getting the orange gasket for the PCV as well, while your at it, only £10 ish and worth changing.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: PCV Failure?
« Reply #4 on: October 08, 2012, 12:31:23 pm »
The front PCV (Common failure) is only about £32 - NOT £90  :grin:
 and its an easy part to fit yourself. Do a search for a how-to guide if you need one.
See here for part numbers:
http://www.mk5golfgti.co.uk/forum/index.php/topic,33782.msg412936.html#msg412936
Gray
Re: PCV Failure?
« Reply #5 on: October 08, 2012, 02:05:31 pm »
DV replacement on your K04........
http://www.mk5golfgti.co.uk/forum/index.php/topic,27003.0.html
DV and PCV diagnosis and repair......
http://www.mk5golfgti.co.uk/forum/index.php/topic,44709.0.html
Revision G Diverter Valve part number. 06F 145 710 G
Revision N PCV part number.                06F 129 101 N
Orange gasket.                                    06F 103 483 E
Offline bacillus
  • -Receive: 453
Re: PCV Failure?
« Reply #6 on: October 08, 2012, 02:24:54 pm »
Personally I would just buy a BSH pcv revamp kit and forget about it ever failing again.
http://dubtek.co.uk/index.php?main_page=product_info&cPath=22_32_33&products_id=477
