Author Topic: TT-RS/Golf R master cylinder  (Read 8168 times)
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« on: November 08, 2012, 02:17:37 am »
Did anyone go for the TT-RS/Golf R master cylinder?
23.81 mm instead of 22.2 mm GTI. I'd expect a stiffer pedal feel.
"You get what you pay for."
Offline vRSAlex
  • -Receive: 253
Re: TT-RS/Golf R master cylinder
« Reply #1 on: November 08, 2012, 10:45:23 am »
Only needed when increasing caliper piston sizing through fitting RS4 calipers etc.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: November 08, 2012, 10:58:06 am »
What about with TTrs brakes, which are larger 4 pots?
Silver is the way !
Offline DFish
« Reply #3 on: November 08, 2012, 11:23:56 am »
or say AP 6 pots?
Fish
« Reply #4 on: November 08, 2012, 12:30:38 pm »
Or even stock Golf R brakes - single pot!
My brake feel is firmer than i remember the ED30 being - even on the TAROX set-up, but it is still not overly hard. :smiley:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #5 on: November 08, 2012, 01:30:41 pm »
From theory if you increase master cylinder by 15 % you'll get 15 % less pedal travel and
increasesed pedal pressures (by 15 %).
It's not just a question of 'need' but a question of what you want. I want a stiffer pedal feel.
Though a new MC isn't really 'cheap', but compared to 4-pots it's not that expensive at all.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: November 08, 2012, 01:52:03 pm »
Any prices for these?
Silver is the way !
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #7 on: January 23, 2013, 08:05:30 pm »
piston size/area
1. stock front caliper:
Golf/GTI - Ate FN3 54 mm caliper: 2290 mm²
S3/R32/R - FNRG 57 mm: 2552 mm²
2. aftermarket - proper match:
AP Racing 6-pot CP7068-00 (355x32 ) > 2350 mm²
Boxster: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
Boxster S: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
993 Turbo: 36 + 44 mm > 1018 mm² + + 1520 mm² = 2538 mm² (on the edge)
Brembo GT 'A-caliper': 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
Stoptech ST-40: 38 mm + 34 mm > 908 mm² + 1134 mm² = 2043 mm²
3. aftermarket - poor match:
Forge: 707 mm² + 1046 mm² + 1164 mm² = 2917 mm²
996 Turbo: 40 + 44 mm >  1257 mm² + 1520 mm² = 2777 mm²
Q7/Touareg/Cayenne (three variants):
34/36/38 mm : 907.920 + 1017.876 + 1134.115 = ~ 3060 mm²
32/36/38 mm : 804.248 + 1017.876 + 1134.115 = ~ 2956 mm²
30/34/38 mm : 706.858 + 907.920 + 1134.115 = ~ 2749 mm²
4. master cylinder diameter:
- 22,22 mm >  388 mm² (some Mk.V GTI, Mk.V + Mk.VI Golf)
- 23,81 mm >  445 mm² (Mk.V R32, Mk.V GTI, Mk.VI GTI, Golf R)
- 25,40 mm >  507 mm² (RS3 + TT-RS)
If you know the piston diameter: Pi * radius² = area
brake fluids
Make
.......DOT Rating.....dry boiling point / wet boiling point
Amsoil DOT 4 - DOT 4 - 580°F (304°C) / 410°F (210°C)
AP Racing 551 - DOT 3 - 527°F (275°C) / 302ºF (145ºC)
AP Racing 600 - DOT 3 - 590°F (310°C) / 410°F (210°C)
AP PRF Racing - DOT 4 - 608°F (320ºC) / 311°F (155ºC)
Ate SL6 - DOT4 + ISO6 -  509°F (265°C) / 347°F (175°C)
Ate Super Blue - DOT 4 - 536ºF (280ºC) / 390ºF (194ºC)
Ate Super 200 - DOT 4 - 536ºF (280ºC) / 390ºF (194ºC)
BMW OEM  - DOT 4 - 446*F (224°) / 311*F (156°)
Bosch - DOT 3 - 491ºF (255ºC) / 288ºF (142ºC)
Bosch - DOT 4 - 509ºF (265ºC) / 329ºF (165ºC)
Bosch - DOT 4+ - 536ºF (280ºC) / 356ºF (180ºC)
Brembo LCF 600+ - DOT 4 - 601ºF (316ºC) / 399ºF (204ºC)
Brembo EVO 500+ - DOT 4 - 520ºF (271ºC) / 336ºF (169ºC)
Castrol GT LMA - DOT 4 - 509ºF (265ºC) / 311ºF (155ºC)
Castrol SRF - DOT 4 - 590ºF (310ºC) / 518ºF (270ºC)
Endless RF-650 - DOT4 -  612°F (323°C) / 425°F (218°C)
GS610 - DOT 4 - 610°F (321°C) / 421°F (216°C)
Gunk HD - DOT 4 - 510ºF (266ºC) / 311ºF (155ºC)
Motul DOT 5.1 - DOT 5.1 - 509ºF (265ºC) / 365ºF (185ºC)
Motul RBF 600 - DOT 4 - 594ºF (312ºC) / 421ºF (216ºC)
Motul RBF 660 - DOT 4 - 617ºF (325ºC) / 400ºF (204ºC)
Neo Super DOT16 - DOT 4 - 610°F (322°C) / 421°F (216°C)
Pentosin Super - DOT 4 - 500°F (260°C) / 338°F (170°C)
Pentosin RBF - DOT 4 - 572°F (300°C) / 392ºF (200°C)
Performance Friction RH665 - DOT 4 - 617°F (325°C) / 395°F (195°C)
Project µ G-four 335 - DOT 4 - 634°F (335°C) / 429°F (221°C)
Prospeed RS683 - DOT 4 - 683°F (360°C) / 439°F (224°C)
TAR•OX Roadrace - DOT 4 - 583°F (314°C) / 401°F (205°C)
ValvolineProSyn - DOT 3/4 - 527ºF (275ºC) / 347ºF (175ºC)
Wilwood Hi-Temp 570 - DOT 3 - 570ºF (299ºC) / 284ºF (140ºC)
Wilwood EXP600 Plus - DOT 4 - 633ºF (330ºC) / 417ºF (213ºC)
Offline gazbutS3
« Reply #8 on: January 23, 2013, 08:50:18 pm »
wouldn't the increased piston area of the tarox set-up make the pedal softer John on the standard master cylinder, more piston area needing an increase in pedal movement???
« Reply #9 on: January 24, 2013, 09:07:36 am »
What are these found on, Holger?
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #10 on: January 24, 2013, 10:03:17 am »
On the Brembo BBK Kit (330x28 discs)
As far as I know this is the same caliper as found on Cupra R (1.8T).
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #11 on: January 24, 2013, 03:39:03 pm »
Mike, a (don't remember) Swiss or German Forum member told me. He runs these Brembos on his Octavia RS.
Offline DFish
« Reply #13 on: January 30, 2013, 10:41:55 am »
AQfter fitting my AP 6 Pots (CP5570's) and found I had a better pedal than with the Cupra/R32/S3 setup fitted. Also found that the ABS kicked in a fair bit earlier, so I've had to re-learn the art of hard braking. ;)
Fish
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #14 on: January 30, 2013, 12:07:24 pm »
What kind pads do you run? AP404?
No wonder the pedal feels firm. It's matched to the R32/S3. The CP7068 kit would provide an even stiffer pedal feel.
 :wink:
piston size/area
AP Racing 6-pot CP7068 (355x32 ) > 2350 mm² (small bore version of CP7040 caliper for Mk.V/VI)
AP Racing 6-pot CP5570: 27.0 + 31.8 + 38.1 > 573 mm² + 794 mm² + 1140 mm² = 2507 mm²
