Author Topic: Slipping Clutch  (Read 8656 times)
Offline gigolo456
Slipping Clutch
« on: January 12, 2013, 09:00:18 pm »
Hi Folks, my clutch has started to slip in the customary 5th and 6th gears, any suggestions if/when I replace plse? Ive a 2005 GTi, 50k miles, and original clutch still; I have all the usual engine mods, and R Tech Stage 2 map!
Ive been reading up on dxd clutch, sounds good, but hearing mixed things bout Sachs! Just hoping I dont need to replace DMF also, but maybe sum of these kits already come with it!? Budget wise, if I have to, I guess a grand or so, including fitting and warranty! (Thanks Hurdy btw for your initial help on this)
Cheers Folks
Andrew
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Slipping Clutch
« Reply #1 on: January 12, 2013, 11:10:09 pm »
I've answered a couple of clutch threads recently. It's pretty much inevitable that your clutch will slip on a mapped car, if not straight away, it will eventually  :sad1:
Check out a Helix clutch - awesome GTI seem to do these at a good price. Not heard anything bad about these. .
If I still had my GTI, that would be my choice  :happy2:
Southbend is another option, although you probably have to buy from the USA as no one seems to sell them over here.
« Last Edit: January 12, 2013, 11:11:57 pm by GrayMK5GTI »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Slipping Clutch
« Reply #2 on: January 12, 2013, 11:12:03 pm »
Darkside developments do southbend iirc
Offline gigolo456
Re: Slipping Clutch
« Reply #3 on: January 12, 2013, 11:28:04 pm »
Cheers will check up on these! Will these performance clutches require act differently to my stock clutch do u know, ie. shorter, longer on pedal, or tighter, etc? The last thing I want is to have one leg bigger than the other, lol!!
Andrew
Offline gigolo456
Re: Slipping Clutch
« Reply #4 on: January 12, 2013, 11:37:19 pm »
I'm assuming the Southbend is the same as the dxd I mentioned!? Goapr.co.uk do them if I assume correctly, although bout 950 incl VAT, and no mention if that includes fitting!? :scared:
Offline AndrewJB
  • die gelbe Baron
Re: Slipping Clutch
« Reply #5 on: January 13, 2013, 05:57:28 am »
of course it doesn't include fitting
Southbend and DXD are the same company, ive got a Southbend Stage2 "Silent" SMF and Organic Clutch kit, its not Silent  :grin:
Offline Dario
  • booosting... :)
Re: Slipping Clutch
« Reply #6 on: January 13, 2013, 08:32:14 am »
i love my st2 "silent" kit ,no sound or any problems  :drinking:
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline gigolo456
Re: Slipping Clutch
« Reply #7 on: January 13, 2013, 11:15:16 am »
Tbf I think the DMF is in this price!? Is there much difference in the actual clutch feel?
Re: Slipping Clutch
« Reply #8 on: January 13, 2013, 11:21:57 am »
You have an R Tech map on your car, have you not asked the the boys there how much and the different options that are available to you regarding updating your clutch. Says on their website £990 fully fitted for Sashs or Helix performance clutch. Worth a call.
My choice, Helix.  :happy2:
Offline gigolo456
Re: Slipping Clutch
« Reply #9 on: January 13, 2013, 11:26:36 am »
Saw that yes, although the dates are a bit out, so prices may b different! But yes, mite give them a call alright, and also Statlers as much more local to me! Is leaving a slipping clutch not adviseable then? :-o
Offline greygti
Re: Slipping Clutch
« Reply #10 on: January 13, 2013, 02:06:02 pm »
No as it will begin to leave heat spots on the face of the DMF
Offline gigolo456
Re: Slipping Clutch
« Reply #11 on: January 13, 2013, 06:46:08 pm »
Edging towards helix I think! :-o
Offline AndrewJB
  • die gelbe Baron
Re: Slipping Clutch
« Reply #12 on: January 13, 2013, 07:27:50 pm »
Mine was fitted to my PD170 TDI and wasn't silent at all, but when we took it of we noticed after 5k it wasn't bedded in (i live in MK so hardly do any start stop driving)
Im hoping in my 2.0TFSI it will be silentish
Offline gigolo456
Re: Slipping Clutch
« Reply #13 on: January 13, 2013, 08:31:20 pm »
Anyone know if the Helix is quiet?
Offline AndrewJB
  • die gelbe Baron
Re: Slipping Clutch
« Reply #14 on: January 13, 2013, 08:45:13 pm »
Helix SMF? no way
The only quiet SMF im aware of is the Southbend kit and as i said above on my TDI it wasn't quiet
