Author Topic: Revo Select Plus - Need Help  (Read 4171 times)
Offline illyun
« on: July 14, 2009, 06:55:47 pm »
Hi Guys.... I'm currently in Holland and tried to use my select-plus switch to disable the car - the security feature.  Problem is, that I forgot to bring the instructions and have never used this feature... can anyone help?  :scared: :sad:
Re: Revo Select Plus - Need Help
« Reply #1 on: July 14, 2009, 07:00:16 pm »
it says it on the back how to turn it off
  • -Receive: 453
« Reply #2 on: July 14, 2009, 07:02:23 pm »
Turn the ignition on, insert the select switch  with the dial set to anti-theft on and wait till you hear a beep.
Remove the switch and turn the ignition off...   :smiley:
Reverse the procedure with the dial set to anti-theft off to disable the protcction.
« Last Edit: July 14, 2009, 07:03:56 pm by bacillus »
« Reply #3 on: July 14, 2009, 07:21:35 pm »
As bacillus says, but wait at least 10 seconds when loading is complete. It gives the system time to settle AFAIK.
Offline illyun
« Reply #4 on: July 14, 2009, 07:23:46 pm »
which one is anti theft on?!  All it says is a,b,c etc...
Offline illyun
« Reply #5 on: July 14, 2009, 07:24:23 pm »
On the switch itself?
« Reply #6 on: July 14, 2009, 07:32:28 pm »
Ah, mine is only a Select switch, but if it's a clue : -
1 = Stock
2 = Performance
3 = Anti-theft On
4 = Anti-theft Off
5 = Firmware Update
Offline chungster
« Reply #7 on: July 14, 2009, 07:41:54 pm »
now could nadeem do this if he had switched to an APR remap???
Offline neg
  • gone old skool
« Reply #8 on: July 14, 2009, 07:53:28 pm »
Just a note when you switch anti-theft off (as in when you come back) the first time you fire up it may not catch immediately like normal, I assume the switch cuts the fuel.
As others have said it should tell you on the back which is anit-theft, its not ABC put it that way.  Unfortunaltey I sold mine with the car otherwise I would have had a look.
Offline illyun
« Reply #9 on: July 14, 2009, 08:00:11 pm »
Well at least they're useful for something...  :evilgrin:  Now then, if my car doesn't come out of anti-theft mode and I'm stuck in Holland......
Offline illyun
« Reply #10 on: July 14, 2009, 08:01:30 pm »
thanks for the replies everyone - you've been really helpful.  I'll try and get some photos of the Ed30 on tour  :happy2:
Offline chungster
« Reply #11 on: July 14, 2009, 08:02:51 pm »
more importantly, DON'T LOSE THE SWITCH!!!!
otherwise enjoy the delights of Amsterdam  :signLOL:
Offline illyun
« Reply #12 on: July 14, 2009, 08:21:17 pm »
Not much delight in being stuck in an office block designing internetworks outside Amsterdam Schipol airport.. can't wait to get back.  problem is, that i have to repeat the experience every week for the next few months... still, its better than not being able to find work so I should be thankful for that.  :innocent:
« Reply #13 on: July 14, 2009, 08:26:19 pm »
yes, they have a controllable map through the OEM cruise control stalk instead of the little box revo use  :happy2:
« Reply #14 on: July 14, 2009, 08:30:48 pm »
I have fully loaded apr stage2+ which allows selection and locking into anti theft, valet, stock or performance via the cruise control stalks
**edit** sorry i take ityou were saying this wouldnt have happened on apr map? lol  Im tired
