Author Topic: Blue Flame back box delete exhaust - Vroom or not?!  (Read 10807 times)
Offline Spadds
« on: February 19, 2013, 01:47:53 pm »
Anyone fitted one of these at all?
http://www.ebay.co.uk/itm/200894156877?ssPageName=STRK:MEWAX:VRI&_trksid=p3984.m1423.l2661
I'm not in the need for a new exhaust yet, and don't 'want to splash £500-600 on a new one until I have to, so I was looking at this to see if it would a)look a bit better, and b) produce a little more feedback from the engine?
I'm assuming you just bolt/clamp it on to OEM system.  I'm not sure if it's useable with other SS manufacturers parts if I were to upgrade rest of system at a later date?
Comments welcomed!
spadds
Offline majinvash
  • Eat, Sleep, Snowboard
Re: Blue Flame back box delete exhaust - Vroom or not?!
« Reply #1 on: February 19, 2013, 02:41:00 pm »
Interested in the answer to this too. I saw the same link and am very tempted to get one too!
Offline Spadds
« Reply #2 on: February 19, 2013, 03:49:45 pm »
I emailed the ebay seller for more info, very quick response recieved.
Basically the b.box delete is with a 2.5" dia pipe which is fine with the stock exhaust.
If you want to use blueflame products in the future, then you'd need to buy a whole new CAT back system as this would be in 3" dia pipework only.
So two options.  Delete pre CAT and add the b.box delete section and keep OEM exhaust,  :wink: OR
A brand new 3" shiny CAT back system!!!!!!! :party: :congrats:
Offline Baz300
« Reply #3 on: February 19, 2013, 05:45:16 pm »
I think you would have to cut your standard exhaust to fit that as the standard one is one piece from the center of the car back.
Offline Spadds
« Reply #4 on: February 19, 2013, 06:26:40 pm »
The supplier said it would fit straight on.... If I had to do any mods I wouldn't buy it.  I'm not sure what the patterns are for the OEM exhaust, can anyone confirm if it would need modding?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #5 on: February 19, 2013, 06:30:51 pm »
The back box delete booms like hell  :sick:
Your best saving for a proper cat back  :happy2:
Offline Baz300
« Reply #6 on: February 19, 2013, 06:31:47 pm »
If you look at this exhaust
http://www.ebay.co.uk/itm/VW-Golf-MK5-MKV-2-0-GTI-Complete-Exhaust-System-/251224511399?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a7e25d3a7
The standard gti exhaust is only 2 pieces, any cat back system will replace only the rear half.
And blueflame do not call it a cat back just suitcase delete, I think you need to cut the standard exhaust just before the rear silencer to fit it.
Offline Baz300
Offline Spadds
« Reply #8 on: February 21, 2013, 10:14:45 pm »
Wow, thanks! :scared:  Glad I didn't buy it.  I think manufacturers should clearly state that mods are required when fitting such kit, or make it so it fits straight in.  I remember buying a front strut brace for an old mk2 gti, and you had to drill and bolt it to the front strut mounts/bulk head...... No chance! :stupid:
Back to the search for a nice exhaust then.............
Offline majinvash
« Reply #9 on: February 22, 2013, 02:33:00 pm »
I messaged Blueflame direct a few months back, just found the email.
Hi Matt,
Is your vehicle fitted with a std system or is the other part Blueflame?.
If the other part of the exhaust is std you need to buy a cat back system with the oem adaptor.(can give you a good price).
If blueflame no problem fitting.
Delivery 7/10 days
Best regards
Warren Simmons
Looks like there could be an adaptor to just use the Catback without having to hack anything.
Offline Baz300
« Reply #10 on: February 22, 2013, 05:21:09 pm »
Hi Matt,
Delivery 7/10 days
Best regards
Warren Simmons
If you buy a cat back from them then it is just an adaptor to reduce the diameter of the pipe to fit the standard front pipe.
The suitcase delete is just a replacement for the backbox so cutting is required.
I think a cat back is around £400-£500 compared to the low price of the suitcase delete.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #11 on: February 22, 2013, 06:45:38 pm »
i have a full BlueFlame system. mine has a middle resonator but the suitcase delete and it sounds great to me. i would not recommend having a suitcase delete AND the middle res taken out tho
PLANS: Stage 2+
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #12 on: February 23, 2013, 10:00:36 am »
I had one one, it sounded good deffo one of the better sounding mk5 systems.
MK7 GTI - ARRIVING DECEMBER
Offline adamfbb
« Reply #13 on: February 23, 2013, 06:01:29 pm »
Fitted one a few weeks ago, does require cutting the suitcase out.
Sounds a lot nicer than standard certainly turns a few heads now! :driver:
Offline islander
« Reply #14 on: February 24, 2013, 10:22:08 am »
I put a system on yesterday from the rear beam back.
The pipe work is smaller at 2.25 inch but the stepping has actually give a lot more torque lower down!
The system had just the silencer and no suitcase rearbox it sounds like a jet!
Would defiantly recommend it to anyone.
Will post a video at some point.
Max
