November 21, 2025, 02:46:09 pm
All Things Mk5
Performance Modifications
Made my own turbo outlet...
Topic: Made my own turbo outlet... (Read 3015 times)
ROH ECHT
Just look at my post count
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
June 29, 2013, 07:29:40 am »
I decided today to make my own turbo outlet by modifying the oem 2.0t fsi outlet...I cut the oem alloy tube down below the pinch on it. Added to it a straight 60mm Dia. coupling tube w/length of 40mm. Then, from a 60mm U/180deg. alloy pipe you'll need to cut the portion needed, which wasn't much, go up from one end a few inches to the 1st cut. Then up from there 4 or so inches, but I'd recommend you mark it as needed to fit the turbo outlet coupling hose and cut it after you are certain of the location of cuts one and two. I actually found a small length of what I needed in a muffler shop scrap bin and the cost was free ;p
Neuspeed, or some one, should hire me...now that I finished up with my MET program, right? ;p
This is what you'd want if buying the section...
This is how mine turned out...
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Re: Made my own turbo outlet...
Reply #1 on:
June 30, 2013, 08:07:55 am »
Looks good. Get shot of the nasty t bolt clamps for some decent JCS high grips though. T bolt clamps leak boost all day long as they don't spread even load.
Build Thread
www.akstuning.co.uk
- info@akstuning.com - 01234 822324
Follow AKS tuning on
Facebook
ROH ECHT
-Given: 113
-Receive: 149
Reply #2 on:
July 18, 2013, 08:54:13 am »
Made a minor change today...it didn't hurt...but boost kicked up another notch both in pressure and quickness to build ;p
THIS...
TO THIS...
E30Dom
-Given: 42
-Receive: 76
Reply #3 on:
July 18, 2013, 09:10:34 am »
So how does it look standard and what would you need to achieve the latest incarnation?
Diesel Daily Hack.
ROH ECHT
-Given: 113
-Receive: 149
Reply #4 on:
July 19, 2013, 05:40:54 pm »
I found this 60mm hose and cut both ends just to simplify and eliminate a couple of extra connections
Dan648v
Won't Shut up.
-Given: 28
-Receive: 26
My Ride:
Reply #5 on:
July 19, 2013, 06:15:40 pm »
Defo more pics needed
E30Dom
-Given: 42
-Receive: 76
Reply #6 on:
July 19, 2013, 07:31:54 pm »
Defo more pics! And what size is the turbos outlet!?
Diesel Daily Hack.
ROH ECHT
-Given: 113
-Receive: 149
Reply #7 on:
July 20, 2013, 09:55:30 pm »
More pics of what? Above, it is installed...
The outlet adapter is from AWE tuning, and I can't find the diameter of it...yet ;p
E30Dom
-Given: 42
-Receive: 76
Reply #8 on:
July 22, 2013, 01:55:34 pm »
Any pictures of what the adaptor looks like, is it just this adaptor, pipe and modifying old discharge pipe to get to this?
Diesel Daily Hack.
danishmkvgti
-Given: 243
-Receive: 155
My Ride:
Reply #9 on:
July 22, 2013, 03:49:03 pm »
All i can say is it's a nice try. IF you are low or tracking the car keep the oem parts in the car as the driveshaft will hit and make a boost leak. trust me i went to the ring with a similar setup and we tried to patch it up with different setups 14 times in 2 days.
Over the top mod list ;o)
lee_vrs
Taking part
-Given: 2
-Receive: 3
Reply #10 on:
July 22, 2013, 09:20:31 pm »
Nice mod
All Things Mk5
