Author Topic: Which wheel seelent?  (Read 5174 times)
Offline George10
« on: July 28, 2013, 10:41:00 pm »
Currently waiting form new wheels to arrive and I would like to seal them before i put them on..
Which is the new seelent to buy?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Which wheel seelent?
« Reply #1 on: July 28, 2013, 10:48:21 pm »
FK1000P.
'07 Red manual
Offline George10
« Reply #2 on: July 28, 2013, 10:59:04 pm »
Cheers  :pomppomp:
« Reply #3 on: July 28, 2013, 11:15:09 pm »
I use poor boys wheel sealant
Offline s3kel
« Reply #4 on: July 29, 2013, 12:14:10 am »
I use swissvax autobahn or you could try gtechniq c5 :)
« Reply #5 on: July 29, 2013, 12:28:34 am »
Only bother with sealant if you clean your wheels very regularly. If you are like me and only clean your car once every 2 weeks then the wax will be of no use, ad brake dust will embed its self. (thats what ive found anyway)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #6 on: July 29, 2013, 06:40:21 am »
FK1000P
The tin is huge, is half the price of GTechniq C5 and cheaper than most other wheel sealants (for the amount you get) and the bonus is that you can use it on your car as well as it is a great sealant.
Offline George10
« Reply #7 on: July 29, 2013, 07:32:41 pm »
I've just ordered some  :happy2:
Offline xjay1337
  • -Receive: 377
« Reply #8 on: July 29, 2013, 08:27:47 pm »
A ceramic coating is the best such as c5 (which is also the same as c1 and c4 confusingly)
Waxes never really last as long often because of the extreme conditions they are put through.  Very high temperature followed by rapid cooling. Waxes can not really deal with that.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re:
« Reply #9 on: July 29, 2013, 08:59:01 pm »
Not true at all.
I tested FK1000P against a C5 that I bought off Richwig on here. I put the FK1000p on one front wheel and C5 on the other. I went away for 8 months and my wife was instructed on how to clean the wheels. Basically she PW rinsed them and the car once a week (over winter).
When I came back both were still protecting the wheels and both to the same extent. I.E similar beading and ease of cleaning.
No doubt if you were to get the microscope out then the C5 may well be doing something better. But in the real world FK1000p performs just as well if not better.
The thing about FK is the ease of application & removal. You can coat all 4 wheels at once (assuming you have a lift or 2 at once if using axle stands) let it cure for 30-60 mins depending on the weather. Then buff off. I always apply 2 coats to ensure full coverage.
C5 is a pain to apply as you have to apply it a sector at a time and buff off straight away or it crystallises. I did a quarter of the wheel at a time. I left it 24hrs and put on another coat (to ensure coverage & fairness for the test)
Don't believe all the hype you read online especially when it comes to detailing. Something I learnt quite quickly. GTechniq make some good products, I have C1, C4, C5 (yes I know they are all the same), C2v3, C1.5v2, G1, G2, G4, G5 & I1 (which is very good stuff)
But there are other products out there that perform just as well and in some cases better. A lot of it is in the eye of the person who has the product. Especially if they have bought it.
FK1000p is a high temp resistant paste sealant. The main decisive factor for me is that it performs just as good as C1,4,5 and will last a few years as the tin is hooooooge.
« Reply #10 on: July 29, 2013, 09:03:06 pm »
I had forgotten id sold you that.
I used C5 when i had my refurb, and it was good.... but my lazy approach to cleaning meant that the brake dust (drilled discs kick out loads of sh*te) just burn through the coating!
Offline greygti
« Reply #11 on: August 04, 2013, 02:58:22 pm »
I'm using auto finesse mint rims at the moment and it seems to be good-only time will tell....
Offline Scotsmanash
« Reply #12 on: August 26, 2013, 06:09:21 pm »
I use poor boys wheel sealant, seems to do the job
Offline xjay1337
  • -Receive: 377
Re:
« Reply #13 on: August 27, 2013, 09:38:02 am »
Not true at all.
It's very true. I myself run Collinite 476s (which is more durable than FK1000p) and it lasts for maybe 3 months tops. I have seen ceramic coatings (and I shall link you to one in a little bit) last for over 2 years on a car with huuuuge 360mm discs and sintered pads.
I would expect a year durability.
Quote
"Just as well" - not better. the durability of C5 and any other ceramic coating is all in the application. The wheel MUST MUST MUST MUST be THOROUGHLY Iron X'd, clayed, Iron X'd again, followed by an IPA wipe down to ensure that absolutely nothing interferes with the bond between the sealant and the clear coat.
Quote
I know what you're saying - regular waxes are easier to apply absolutely. However C1/C4/C5 is not "hard" to apply and you have about a 15-20 minute period where you can wipe it away without anything being formed. You can apply it completely to one entire wheel quite happily. The newer versions C1+ can be left for several hours! They were super difficult once upon a time but not as of late.
Quote
I completely agree. I don't speak from hype I speak from experience. I take everything with a pinch of salt but on Detailing World most people there know their stuff - and if 50 people are saying that it works better for them than a regular wax then it probably is better than a regular wax.
Quote
The cost -> durability is very good in terms of the tin size. That's probably the deciding factor ultimately, the cost.
http://www.detailingworld.co.uk/forum/showthread.php?t=317011
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #14 on: August 27, 2013, 12:14:13 pm »
iron x > polish > poorboys. :happy2:
Diesel Daily Hack.
