Author Topic: Relax Silver GTI *NEW PICS, Lowered* SRS Wings-R8 BBK-H&R Ultra Lows  (Read 51501 times)
Offline adzg60
Re: Relax Silver GTi *2016 Update* 19" ABT, Ultralows SRS Tec wings and more!
« Reply #90 on: February 07, 2016, 07:23:16 pm »
Very nice, do you think it will do much on weight distribution, I know it's not the heaviest thing in the world but every little helps
Offline jaffa
  • -Receive: 44
What do you think about the srs tec wings? I still need to get some
Offline airbagaaron
« Reply #92 on: February 07, 2016, 08:29:41 pm »
I've no idea, I can image it will help slightly, but it's more for looks and cleaning up the bay I'm doing it if I'm honest.
Offline airbagaaron
Delivery was around a week, they fit great, all panel gaps etc are spot on, only thing I'd suggest is bolting on the bumper bracket with some small bolts and wide washers As the standard fixings won't work. Buy them direct from SRS tec as its around £40-£50 cheaper than buying from a UK supplier.
I can't wait to get them painted and wheels on!
Offline adzg60
« Reply #94 on: February 07, 2016, 08:38:14 pm »
Gives you a nice space where the battery was to extend your intake with a 90 bend and relocate the filter further from the engine with a decent heat shield too
Offline airbagaaron
« Reply #95 on: February 07, 2016, 08:43:08 pm »
I actually cut the 90 off and put the filter back on so its closer to the engine, think it looks cleaner, sort of look I'm trying to achieve.
Offline airbagaaron
« Reply #96 on: February 18, 2016, 08:48:44 pm »
Update, fitted PCV deleted and trail fitted wheels to see what the wings gave me on front clearance, May have to shave a few mm off the fronts to pull them in a bit, also waiting on edition rear and bought a set of R8 calipers .
Offline airbagaaron
« Reply #97 on: February 23, 2016, 09:59:02 pm »
Couple more updates, left my wheels off at a local engineering firm to get 4mm lathed off the rear to increase the ET to ensure they fit better on the front and rear, 4mm will allow the rear to pull in and allow me to drop the car more at the front.
Also took delivery of my front brakes, just have to source disks which shouldn't be too hard in talks with Kyle of the forum here. All is coming together nicely. Once I get the brakes on and wheels back sending car off to paint before I head off to UD.
Thanks for looking.
Offline airbagaaron
« Reply #98 on: February 24, 2016, 10:20:09 pm »
Got my wheels lifted today, two day turn around was very happy with the work and cost to do it! Will use him again for another few bits and pieces.
Also got my edition rear, so put it on but the sun was setting so picture is t that great, hope to have brakes painted and on over the weekend along with the wheels painted ready for tyres off to paint next week  :happy2:
Offline airbagaaron
So another quick update,  :smiley:
Got brakes printed and mounted, bought a ramair filter to replace existing, got black caps for coolant and washer bottle at UD. Also got wheels painted. Run into an issue with the wheels, the engineering firm i got to mill the wheels down 4mm took them down un-level which almost looked like they took 4mm off one side and 2-3mm off the other side creating an angle that i never noticed until the wheels were put on the wheel balancer. Issue was sorted in the end up and with freshly painted wheels it was a nightmare  :scared:
Quick picture below of the car before i send it off to the paint shop. Get the high adjusted and the rear camber sorted all should be ok.
Thanks for looking!
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
Looking good dude. What colour are you going for or is it a secret?
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
looks spot mate  :happy2:
Offline airbagaaron
Aww no, just painting it the same colour with a black grill, playing with the idea of doing the inserts in the splitter and rear bumper untied grey the same colour as the wheels but unsure yet.
Offline airbagaaron
Offline jayha11
Sounds like a good plan for the grills and splitters i think  :happy2:
