Author Topic: How To: EGR Valve / EGR Cooler Delete Mk5 TDI (BKD / BMN)  (Read 314352 times)
Offline Matto
  • -Receive: 116
Re: How To: EGR Valve / EGR Cooler Delete Mk5 TDI (BKD / BMN)
« Reply #15 on: September 07, 2013, 06:07:21 pm »
Andrew, mine went on the rollers at the last TDISport day couple of weeks back. Only averaged 200 over 3 runs. 216 on the Shark rollers when it was mapped. Chris said throttle response felt flat plus there was a dip in my power curve. For 200bhp it should hardly smoke, mine pummels so I believe there is room for improvements.
Offline AndrewJB
  • die gelbe Baron
« Reply #16 on: September 07, 2013, 06:32:57 pm »
Ah right your going to be hard pushed to see anything over 210-215 though, As said above i think the RR under reads aswell
I had the Stage 2 (Made 216bhp) and Stage2+ (228bhp) map on my PD170
Stage 2 smoked but was still legal levels, Stage2+ was totally illegal
Offline vRSAlex
  • -Receive: 253
« Reply #17 on: September 07, 2013, 10:30:44 pm »
That long grub screw has a hole down the centre of its. Its in the kit to use for the boost gauge tap.
Great write up.
Follow AKS tuning on Facebook
« Reply #18 on: September 07, 2013, 10:37:34 pm »
mine hardly smokes at all or so am told..be interesting to see what its like when I get it back from the tuners
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Re: How To: EGR Valve / EGR Cooler Delete Mk5 TDI (BKD / BMN)
« Reply #19 on: September 07, 2013, 11:10:20 pm »
Great write up.
Ahhh... So I shouldn't use it to blank off the vacuum hose then. Lol.
What do you normally block the vacuum hoses with?
Cheers!
Jas
VCDS (Preston, Lancashire)
Offline AndrewJB
  • die gelbe Baron
« Reply #20 on: September 08, 2013, 07:15:25 am »
There is usually a smaller grub screw which is sealed to go in there
Offline vRSAlex
  • -Receive: 253
« Reply #21 on: September 08, 2013, 09:30:31 am »
That one is for the delete pipe.
Just use a grub screw without a hole down it.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #22 on: September 09, 2013, 11:13:11 pm »
Guide updated
  • EGR vacuum pipe
    labelled parts of the EGR delete kit
    mentioned egr cooler differences for BMN (PD 170) engine.
v1.2
Offline Biano44
  • The CC GT 200
« Reply #23 on: September 14, 2013, 08:16:27 pm »
Brilliant write up. You should do more of them! :happy2:
I still think I'll be taking mine to Alex though......Far easier.
Ta
Matt
slizza786
« Reply #24 on: February 16, 2014, 08:18:27 pm »
Fantastic fantastic FANTASTIC tutorial. Used this on my audi a3 8P BKD engine with the hand of my mate and managed to clean my valve out and the avd. I used Valvoline EGR cleaner (£7 incl next day p+p from ebay) and it worked perfectly. Disassembly was a b*tch!!!!!, cleaning was fine, reassemly was not bad.
Some stuff that were not pointed out in the tutorial were some hoses connected to the egr and maf pipe that needed to be taken off but they were no problem at all. I would also recommend taking off the cooler and this allowed alot of extra space and ten mins to take off. Also i recommend using a proper allen bolt kit with extenders and proper wrenches and standard allen  keys are a b*tch to use!
some have said that only cleaning the egr and avd will not show much of a difference in performance but i beg to differ. I say a change  in pickup, high torque on lower revs so really pleased for a job that cost me £7 to do.
Next job will be to clean the turbo vanes with the Mr Muscle trick as this is proven to help the performance of the car ALOt aswell as clean the turbo for only £4!!
This helped solve my P0401 error code.
Once again fantastic  thread!!!!
Before
After
Offline Sjw_Vw
« Reply #25 on: September 06, 2014, 10:46:24 am »
Awesome write up! I've realised I need/want a few extra bit's before I get mine fitted by a friend.  :happy2:
Stirks
« Reply #26 on: October 08, 2014, 07:39:01 pm »
On the BMN engine isn't the EGR controlled by the ECU? I don't seem to have a vacuum pipe just a plug plugged into the side of the EGR valve. I'm a bit worried about what to do if I delete mine. I read it can send the car into limp home mode.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #27 on: October 08, 2014, 07:56:28 pm »
It is controlled by ECU on the BMN engine, I'm not 100% sure of the answer regarding limp mode.
Dark side Developments may be able to answer.
Alternatively, you could try unplugging the connector and see what happens, if you have the means to clear the fault code afterwards?
Jas
Offline Matto
  • -Receive: 116
« Reply #28 on: October 08, 2014, 08:00:41 pm »
Yes it is. You will have to have it mapped out.
As @jason_rmh has just said you will get a fault code. I used to get one as it know it has been unplugged but was removed in the mapping I have.
Offline murph81
  • -Given: 17
« Reply #29 on: February 15, 2015, 02:26:04 pm »
Nice write up, thinking of doing this on my A3.
