Author Topic: rns 510 mfd3 aerial adaptor  (Read 3549 times)
Offline muchgti
  • IF YOU AINT RUBBING YOU AINT DUBBIN
« on: September 02, 2009, 07:47:25 pm »
just bought a rns 510 sat nav system, pluged it all in an then realised the aerial plugs are different does anyone know which adaptor i need as ive seen over 5 different ones on ebay and i dont know which to get.
thanks
Offline ollie288
Re: rns 510 mfd3 aerial adaptor
« Reply #1 on: September 02, 2009, 07:49:16 pm »
Would be interesting as I just got one!  :popcornsoda:
Offline QD MBE
  • -Receive: 102
« Reply #2 on: September 02, 2009, 07:52:15 pm »
what i did was to get the aerial plugs in your hand,and carefully push the centre metal part of the plug out of the plastic part.  You should be left with 2 bare metal plugs, and two plastic shrouds with 2 very small metal circlips inside (brass coloured).
I just fitted mine and secured the leads using a very small tie wrap to the fan aperture.  No problems in operation.
Either this or buy the proper converter from VW for about £20.
Offline QD MBE
  • -Receive: 102
Offline QD MBE
  • -Receive: 102
Offline 182_blue
  • -Receive: 54
« Reply #5 on: September 02, 2009, 08:08:23 pm »
As above,i just popped the plastic fakra connectors off, leaving the metal connectors underneath which fit perfectly onto the RNS
Offline QD MBE
  • -Receive: 102
« Reply #6 on: September 02, 2009, 08:09:28 pm »
It certainly worked well.
« Reply #7 on: September 02, 2009, 11:52:29 pm »
Believe me, it's a very easy thing to do.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #8 on: September 03, 2009, 08:55:29 pm »
You only need to remove one of the plastic housings. The other fits straight on.
#1493
