July 05, 2026, 11:33:38 am
General
Detailing
Autobrite snow foam lance - what am i doing wrong?
Topic: Autobrite snow foam lance - what am i doing wrong? (Read 2603 times)
Timmyb007
Taking part
-Given: 2
-Receive: 1
September 24, 2013, 09:50:30 pm »
As above, despite having the lance set full to minus i cannot seem to get a thick foam. Consequently it runs off quickly and doesn't lift any of the dirt etc. It even leaves water marks meaning I end up cleaning normally. What concentration do you guys use? I am using superfoam.
Kinks
Always Involved
-Given: 3
-Receive: 1
Re: Re: Autobrite snow foam lance - what am i doing wrong?
Reply #1 on:
September 24, 2013, 09:52:47 pm »
Use about 1 inch of foam mix with hot water and a splash of washing up liquid
Sent from my GT-N7105 using Tapatalk 2
Timmyb007
Taking part
-Given: 2
-Receive: 1
Reply #2 on:
September 24, 2013, 09:57:16 pm »
Does it stay on the sides OK?
Kinks
Always Involved
-Given: 3
-Receive: 1
Reply #3 on:
September 24, 2013, 10:02:37 pm »
Water pressure is the next thing. Are you using a good pressure washer!! If so sounds as if the foam mix is a duff
Timmyb007
Taking part
-Given: 2
-Receive: 1
Reply #4 on:
September 24, 2013, 10:14:34 pm »
What effect would low pressure have? Might try using more mixture next time and/or use a different pressure washer.
Last Edit: September 24, 2013, 10:22:49 pm by Timmyb007
Kinks
Always Involved
-Given: 3
-Receive: 1
Reply #5 on:
September 24, 2013, 10:51:12 pm »
Its the pressure that creates the foam it works on a venturi the higher the pressure the better the mix
Kinks
Always Involved
-Given: 3
-Receive: 1
Reply #6 on:
September 24, 2013, 10:53:25 pm »
When I use mine it will hold for three mins at least and leaves a clear surface when rinced
Horatio
Won't Shut up.
-Given: 23
-Receive: 39
Reply #7 on:
September 25, 2013, 11:40:02 pm »
Do you clean it after every wash? I found that after two washes the gauze would clog up and the foam wouldn't foam up nicely. I usually soak it in warm water, squirt a bit of cillet bang in the holes and a rinse through
s3kel
Always Involved
-Given: 7
-Receive: 7
Reply #8 on:
September 26, 2013, 12:35:34 am »
Could be an easy fix ,try running hot water through the lance to clean it as the metal gauge could be clogged up ..have to played about with the black knob adjuster + and - while pressing the pw gun ? If all fails it may need a new metal gauge ..
http://www.detailingworld.co.uk/forum/showthread.php?t=84349
Last Edit: September 26, 2013, 12:40:35 am by s3kel
General
Detailing
