Author Topic: Engine shut down under boost - fail safe?  (Read 18354 times)
  • -Receive: 453
Re: Engine shut down under boost - fail safe?
« Reply #45 on: February 22, 2014, 11:50:46 pm »
The difference between the two is?
just the brand name?
Bosch supplies VW with the lambda sensor. There is a slight superficial cosmetic difference between the two but the sensor is identical. I should know as I'm using the Bosch one.   :smiley:
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #46 on: February 23, 2014, 08:21:32 pm »
Cheers Ayoub  :drinking:  will look into this first before thinking about changing!
Well today, I started of with a simple boost/vacuum leak test, the objective was to find bubbles from where I had sprayed the different parts with soapy water, no bubbles, none seemed to be sucked away either, I replaced the PCV gasket, nice new one in there now, replaced all the boost hoses in around the DV, serviced the DV, some fresh forge grease in, added a custom spacer in, only cost 10p, so thought I would try it,  re-fitted the throttle body hose, as I was not 100% happy with the fit, clips all tightened up, replaced the MAF sensor with a spare I had, scanned and out for a test drive, I have to say the car drives great  :driver:  love it... But problem still there!
The next thing I would like to try, is cleaning the throttle-body flap, what would be the best to use?
My idle seems to tick over between 720-760 rpm's, can this be adjusted in anyway?
Silver is the way !
  • -Receive: 453
« Reply #47 on: February 23, 2014, 09:46:04 pm »
afaik there's no way to alter the idle speed even with vcds.
« Reply #48 on: February 24, 2014, 01:36:58 am »
Engine speed sensor.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #49 on: February 24, 2014, 11:55:44 pm »
Does or can this adjust idle speed??????
Silver is the way !
Offline vRSAlex
  • -Receive: 253
« Reply #50 on: February 25, 2014, 04:47:06 pm »
Nope.  It reads the speed.  The idle is in the mapping.
Get rid of the forge valve and try a rev G.  Could also be a small leak from the brake servo pipes.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #51 on: February 25, 2014, 07:42:15 pm »
cheers Al
Will give that a try  :happy2:  Also where would be a good place to start searching for any leaks from the brake servo pipes ???
Silver is the way !
  • -Receive: 453
« Reply #52 on: February 25, 2014, 08:34:07 pm »
Probably cheaper to just get a new hose if there is any doubts for just under £29. And you will need the small green plastic bung as well if you get a new hose part #  056129777
http://www.mk5golfgti.co.uk/forum/index.php/topic,79635.msg827917.html#msg827917
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #53 on: February 25, 2014, 09:30:31 pm »
Thanks Ayoub, what can cause these to leak, would they be known to failure ?
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #54 on: December 08, 2015, 02:40:47 pm »
Anyone ever figure this out yet as the problem is still here...
 :sad1: :fighting: :fighting: :fighting:
Silver is the way !
