Author Topic: Eibach vs H&R  (Read 60565 times)
Offline chris-182
Eibach vs H&R
« on: February 20, 2014, 10:57:37 am »
Hi all,
I'm new to the VAG scene and looking to get some lowering springs on my GTI.
What are peoples opinions on the Eibach sport lines compared to the H&R alternative. I'm not fussed on getting massive lows, just a better ride hight and to try and keep the comfort as close to OEM as possible.
Ideally I'd want around a 30mm drop
Cheers!
Offline Marc-5-GTI
Re: Eibach vs H&R
« Reply #1 on: February 20, 2014, 11:11:49 am »
H&R go 30mm
Eibach go 20/25mm front/back
I have eibachs and I'm happy where they sit and how they ride
Offline Karl_mac_
Re: Eibach vs H&R
« Reply #2 on: February 20, 2014, 11:29:01 am »
I have eibach sportline and very happy with them. Great comfort, has a good stance but isn't so low as to be unpractical.
VW Golf GTi DSG2.0 TFSI : DSG : BBS LM : Blueflame exhaust : Pipercross Venom Induction : Eibach Springs
VW Lupo1.4l : Automatic : White : Stickers.
Offline tomanni
Re: Eibach vs H&R
« Reply #3 on: February 22, 2014, 12:52:27 pm »
I'm on H&R springs, went for these as I liked the drop more than the Eibachs.
Rides fine, only slightly harder than standard.
As far as I can see it's personal preference really.
Offline Damian @ DPM
  • DPM Performance
Re: Eibach vs H&R
« Reply #4 on: February 25, 2014, 01:51:52 pm »
Personally I prefer the stance and ride quality that the Eibach kit gives you over the H&Rs.
Damian @ DPM Performance
Advertising removed... (for the time being)
Offline vRSAlex
  • -Receive: 253
Re: Eibach vs H&R
« Reply #5 on: February 25, 2014, 04:45:33 pm »
I'm the opposite.  Find the Eibach drops the front more than the rear and gives it an odd look.  The H&R is a nicer ride and is an even drop.  Both are a well made spring.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
Re: Eibach vs H&R
« Reply #6 on: February 25, 2014, 05:04:35 pm »
Totally agree with Alex, defiantly a more even stance with the H&R's, slightly harder but great handling springs  :happy2:
« Last Edit: February 26, 2014, 07:55:09 pm by scopes »
Silver is the way !
Offline chris-182
Re: Eibach vs H&R
« Reply #7 on: February 26, 2014, 12:49:05 pm »
Cheers guys,
I think i'm going to get some H&Rs :) busy month as i will be getting a FMIC, GFB DV and a map also :)
Offline bigeyd
  • -Receive: 31
Re: Eibach vs H&R
« Reply #8 on: February 26, 2014, 01:30:24 pm »
Cheers guys,
Try this for a price on the springs http://www.mk5golfgti.co.uk/forum/index.php/topic,75129.45.html
Offline chris-182
Re: Eibach vs H&R
« Reply #9 on: February 26, 2014, 07:05:46 pm »
brilliant! thanks!
Offline GLIDN
Re: Eibach vs H&R
« Reply #10 on: February 26, 2014, 11:48:26 pm »
Having driven in Manual and DSG gti's with both H&R's and also Eibach's fitted.
Personally, the Eibach's was a much better drive, smoother and absorbed bumps better.
As alex has pointed out, it does tend to lower the front more than the rear thou.
with the H&R's, I found the springs to not really be as forgiving as the Eibach or OEM.
Also uneven surfaces are more noticeable with H&R's fitted.
Even lowering thou.
Either way you go. The horrible factory rear bounce from the OEM springs on the highway are gone.
Actually, I have driven a car with APEX springs. It was by far the closest for lowering and bump absorbing as per OEM.
So for a cheap springs the APEX work very well.
If I had to choose between your 2 options I would always pick the eibach's over the H&R's.
Re: Eibach vs H&R
« Reply #11 on: February 27, 2014, 01:00:12 am »
100% happy with my H&R springs. Just the right amount of drop to make it handle better but not be so low you have to pussyfoot around.... And the ride is almost as comfortable as stock :happy2:
Offline andyR43
Re: Eibach vs H&R
« Reply #12 on: February 27, 2014, 05:14:36 am »
Happy with the drop and performance of my H&R springs too. As others have said they're lower than the Eibachs but not too low.
Keeping it original..............or not!!
Offline GLIDN
Re: Eibach vs H&R
« Reply #13 on: February 27, 2014, 05:26:09 am »
There you have it Rich, same answer from all H&R owners.
Eibach honestly drives nicer than stock 100% of the time.
Re: Eibach vs H&R
« Reply #14 on: February 27, 2014, 08:28:06 am »
So softer? More compliant?
