Author Topic: Ed30 Temp Gauge Drop When Coasting  (Read 20256 times)
Offline Neil 54
Re: Ed30 Temp Gauge Drop When Coasting
« Reply #30 on: January 07, 2015, 07:43:54 pm »
i dont know how it affects performance but after having mine done it definitely felt like it was more responsive
« Reply #31 on: January 07, 2015, 07:50:36 pm »
Having a new Stat fitted in a few weeks as mine drops a fair bit once cruising so def FUBAR'd. Be good to see if it improves anything, can't see where but you never know.
Offline DomBacon
« Reply #32 on: January 08, 2015, 10:04:19 pm »
@vRSAlex how does it hurt power?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #33 on: January 09, 2015, 06:59:52 am »
I didn't notice any difference power-wise but the car ran marginally better afterwards. With the ECU attempting to get the car to operating temperature it will over-fuel a bit and that will hurt MPG and cause buildup of carbon in the combustion chamber (long term).
Best to get it fixed @DomBacon
Offline DomBacon
« Reply #34 on: January 09, 2015, 08:43:42 am »
Mines not boosting how it should and I've ran it through vcds plenty of times!
It's been like this for a while now!
Offline mo
« Reply #35 on: January 22, 2015, 04:15:15 pm »
Picked my car up this morning after having my main thermostat changed and i definitely notice a difference in power.Feels much more responsive. My car has felt low on power for as long as i can remember and couldn't put my finger on it until the temp guage started to drop from 90 degrees on the motorway and then take nearly 40 mins to reach 90 degrees.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #36 on: February 01, 2015, 07:49:54 pm »
Ok so a little help needed please peeps  :innocent:
I think i have the main thermostat problem, but someone riddle me this, i've got a GTI which was orginally a BWA engine code, but have since converted to a CDL. Anyone know which part number i'd need?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #37 on: February 01, 2015, 07:53:47 pm »
You probably need the same one as the ed30.
Best way to check would be to take down the number plate of a Golf R on Autotrader and go down to your local VW and get the part number for that car  :happy2:
Offline doylebros
  • -Receive: 310
« Reply #38 on: February 01, 2015, 08:25:27 pm »
Corrected
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1737&ein=2011&f=649&hauptgr=1234567890&hg=1&grf=012102649&bf=12102&hgug=121&ug=21&parent_id=3045259
If it's CDLC engines it's
32 - Seal 06B 121 119 B - £4:08
31 - Regulator 06F 121 111 H - £49:86
Full retail inc vat
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #39 on: February 01, 2015, 08:41:18 pm »
Corrected
Full retail inc vat
So the ED30/CDL revision "H" will be compatible with my car you think John?
The more i think about it the more confused i'm getting, as when i did the conversion to CDL it was a bare block, meaning my BWA gti thermostat would have gone back on, revision "F"?
So is there actually any difference between the stats?
Offline doylebros
  • -Receive: 310
« Reply #40 on: February 01, 2015, 09:06:58 pm »
Corrected
Full retail inc vat
Yes they look physically different on these illustrations!
If you fitted the BWA gear back then you need
regulator part number 06F 121 111 F - £49:86
seal 06B 121 119 B - £4.08
full retail Inc vat.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #41 on: February 01, 2015, 09:14:52 pm »
So I need to stick to the original engine codes thermostat you think?
Offline doylebros
  • -Receive: 310
« Reply #42 on: February 01, 2015, 09:22:52 pm »
I would cause it's to match your existing coolant system hose layout so (F) ending is the way to go, and as I said (H) ending regulator looks physically different. :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #43 on: February 01, 2015, 09:40:40 pm »
Cheers John  :happy2:
Offline doylebros
  • -Receive: 310
« Reply #44 on: February 01, 2015, 09:42:45 pm »
Happy to help Freddy :wink:
