Author Topic: Revo Ceramic Intake - clonk noise!  (Read 12848 times)
Offline cupra_k1
Re: Revo Ceramic Intake - clonk noise!
« Reply #45 on: July 21, 2014, 02:20:27 pm »
The "putting" noise sounds like the checkvalve in the rear PVC breather pipe to me.
Do you have a PVC revamp / catch can fitted?
Offline edition30jmr
  • ED30
« Reply #46 on: July 21, 2014, 02:42:15 pm »
Nope I haven't got either fitted the car is completely standard apart from the revo kit!
Ed30 Beast!
  • ED30
« Reply #47 on: July 21, 2014, 08:17:02 pm »
Right then guys, Rich when the ignition is on but not engine when I press the throttle I get a click then once I release the throttle I get another click is that normal? And I checked the dv seems to be fine as does the pcv but I'm going to get it on a diagnostic machine for the sake of £50 and that will be piece of mind, oh and I tried it with the engine cold and it still does it then too, just thought id rule that out!
Ed30 Beast!
  • ED30
« Reply #48 on: July 23, 2014, 09:31:10 am »
Anyone know if those clicks are normal?
Ed30 Beast!
« Reply #49 on: July 23, 2014, 09:56:25 am »
The clicking will be the throttle body.
  • ED30
« Reply #50 on: July 23, 2014, 10:05:28 am »
So do you think the loud donk is the throttle body also?
Jay
Ed30 Beast!
« Reply #51 on: July 23, 2014, 10:11:15 am »
Hard to say, but I don't think so. Can't you locate the noise?
  • ED30
« Reply #52 on: July 23, 2014, 10:21:55 am »
I'm going to take the engine cover off tonight and have a good look and listen and try to feel in different places to see if when it makes the clonk if it vibrates or anything anywhere! I'm thinking of buying a VCDS cable so I've got one for future use!
Ed30 Beast!
  • -Receive: 453
« Reply #53 on: July 23, 2014, 07:41:47 pm »
Just asking but did you install the nylon washer on the bolt that secures the intake to the engine?
  • ED30
« Reply #54 on: July 23, 2014, 07:55:08 pm »
Yes and does it need any washers inbetween any of that? I used a washer the other side of the metal part (closest to engine) and another washer against the intake pipe after the plastic/nylon washer.
Ed30 Beast!
Offline vRSAlex
  • -Receive: 253
« Reply #55 on: July 24, 2014, 03:54:53 pm »
As I said before.  Its the diverter valve.  Get a new 'G' on there and it will stop.  Had the same thing on a few cars now.
Doesn't cause any issues as it is anyway.
Follow AKS tuning on Facebook
  • ED30
« Reply #56 on: July 24, 2014, 04:26:36 pm »
Il have another look today Alex, thanks for the help!
Ed30 Beast!
Offline Marshall
Re:
« Reply #57 on: July 25, 2014, 07:28:43 pm »
My S3 has always done this and its only noticeable when an intakes fitted.
I've already replaced the dv with a rev G and replaced the pcv but its still there.
On the Audi forum theres a few people mentioned it.
The noise comes through the intake and its not dependant on which intakes fitted.
Doesn't cause any problems and I only ever notice it when putting the car in the garage.
MISANO RED RS3
  • ED30
« Reply #58 on: July 31, 2014, 10:04:39 pm »
New DV Rev G fitted and it still makes the noise but slightly quieter! Hmm any ideas?
Ed30 Beast!
Offline Marshall
Re:
« Reply #59 on: July 31, 2014, 10:38:09 pm »
Normal
MISANO RED RS3
