Author Topic: <how to install OEM LED license plate lights>  (Read 8121 times)
Offline K9
  • VW LifeStyle
« on: October 17, 2014, 06:34:38 pm »
So i thought i do a quick writeup how to change lincense plate lights from oem yellow light to oem led lights. It's pretty easy but will show with pics how everything is done for the people who not know or are unsure how it's done.
The car is a VW golf mk5 gti 2005 dsg.
You can find the unit from this Ebay seller. http://www.ebay.com/itm/271497461648?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
( this is my frist how-to so i will be editing this thread now and then )
1) get the unit(s)
2) Wash you car!  :happy2:
3) This is how the old oem look like. You can remove it by unscrew the 2 screws you can see...
4) After that you should try to pray the right side out as showed in the pic 8 you dont need to use much of force to get this out! )
5) after praying the one side out, you just start pulling the hole unit out of there. It will come with the connector.
6) Undo the clip and pull it off. easy! clean the old one if you so want. but don't let the connector fall inside the bumper.
7) Get the new oem led unit and just reinstall it by pushing the connector to the unit and Klik!
8) just push the new unit in by starting with the left side as you se there is 2 small tabs, after that just push the right side in and you will hear a klik and it's done! you dont need any screws for the new unit.
the same thing for the other side! should be no problems.
If this have done before feel free to remove this how-to :)
Offline wardyed30
Re: <how to install OEM LED license plate lights>
« Reply #1 on: November 07, 2014, 09:56:44 pm »
Have you had any problems with your car saying the number plate bulbs not working ? With the led lights
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #2 on: November 07, 2014, 10:14:44 pm »
I'm running the same ones on my car, can confirm no issues  :happy2:
Offline K9
  • VW LifeStyle
« Reply #3 on: November 08, 2014, 05:01:28 pm »
yeap no dash error ( light bulb out ) have been running them now for some time and still going strong :)
Offline wardyed30
« Reply #4 on: November 14, 2014, 08:30:43 pm »
I have had some come fitted them last night no more error light coming on
Offline K9
  • VW LifeStyle
« Reply #5 on: November 23, 2014, 07:43:58 pm »
bump still working fine!
Offline MKV_Sean
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,100031.0.html
Re: &lt;how to install OEM LED license plate lights&gt;
« Reply #6 on: November 26, 2014, 08:47:54 pm »
Will be doing this mod myself. Had standard LED bulbs in but kept getting the warning light, drove me insane. Nice little write up btw
Sent from my iPhone when I should be working!
VW MK5 Gti DSG 2.0 TFSI
Offline SimonK24
« Reply #7 on: November 27, 2014, 01:26:56 pm »
I need to do this to my car, really modernises the look of the car I think!
Offline Golf_GT_TDI
  • -Given: 45
« Reply #8 on: November 27, 2014, 01:39:34 pm »
Pictures can't do them justice, well worth the extra they cost over generic LED bulbs and lamps  :happy2:
Offline Jkay
« Reply #9 on: November 27, 2014, 04:15:59 pm »
Neat guide @K9  :happy2:
I got around to installin these and they worked a treat but one day while I was driving it popped up that 'number plate light not working' so I pulled over to see what the story was and both werent working so I just switched them off and back on again and they worked for another while and them the same problem happened. This happens all the time now.
Has anyone else experienced this or similar? I got some for a Mark VI as well and it has the fault on the dash but the lights work perfectly.
'07 GTI
Offline Golf_GT_TDI
  • -Given: 45
« Reply #10 on: November 27, 2014, 04:59:43 pm »
What part number are yours?
Offline Jkay
« Reply #11 on: November 27, 2014, 07:20:45 pm »
1K8 943 021 C
I got them on German ebay.
'07 GTI
Offline K9
  • VW LifeStyle
« Reply #12 on: November 27, 2014, 07:53:20 pm »
1K8 943 021 C
you tried to clean the connectors if there is dust etc?
Offline Golf_GT_TDI
  • -Given: 45
« Reply #13 on: November 27, 2014, 08:02:23 pm »
Hmmm not sure then, not had any errors at all with mine  :happy2:
Offline K9
  • VW LifeStyle
« Reply #14 on: November 27, 2014, 08:12:32 pm »
mine have worked fine! no error yet  :happy2:
