Author Topic: MK6 emblem mech on MK5  (Read 4029 times)
Offline eos
« on: October 20, 2014, 11:33:04 am »
I've picked up a MK6 emblem with mechanism, I'm assuming it's just plug an play for my MK5 mechanism and emblem that has whiteworm?
Also does anyone have a link to a YT guide on removing the boot door trim to fit it?
Re: MK6 emblem mech on MK5
« Reply #1 on: October 20, 2014, 11:50:26 am »
Yeap, plug and play. Wiring loom can be a stretch as the connector is on the tuther side but no biggy. As for removing the trim........remove the 2 screws inside the grab handle areas and pull from the bottom and work your way around the trim, it REALLY does take some effort.
Offline eos
« Reply #2 on: October 20, 2014, 11:54:50 am »
Awesome.
Is the boot trim held on by the metal clips VW seem to like or is there plastic that clips onto the metal?
Would picking up a trim removal tool be a good idea to save destroying the plastic with a flatblade?
« Reply #3 on: October 20, 2014, 12:02:34 pm »
Trim is held in place via about a dozen metal clips and is also held by a couple of plastic bits (can't explain them). No trim removal tool will help for this one, its brut force i am afraid, get your hands under a bottom corner where the plastic is strongest and pull.
Good luck, I've removed my a fair few times but the last time i failed. Reply #267.......
http://www.mk5golfgti.co.uk/forum/index.php/topic,76801.255.html
Offline eos
« Reply #4 on: October 20, 2014, 12:13:40 pm »
This sounds like it's going to be um fun... :scared:
Where are the plastic bits you're on about located on the trim as I assume they're the main clips then all the metal ones are secondary?
« Reply #5 on: October 20, 2014, 12:14:39 pm »
^^^^ The corners IIRC.
Offline eos
« Reply #6 on: October 20, 2014, 12:41:23 pm »
After looking at the clip locations on the bay (checking prices now in case I break it) can't you just reach in through the lamp access holes and squeeze the metal clips while pulling on the trim?
Or am I missing something here :stupid:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #7 on: October 24, 2014, 07:09:23 pm »
nope, you need to move the wiper motor and take the 3 screws out on the boot handle and twist it to remove
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline eos
« Reply #8 on: October 25, 2014, 08:35:56 pm »
Yup that's exactly how I did it in the end, I've taken some pics of the process I'll post up at some point :)
I only "slightly" damaged the rear trim...I swear the glue it on there.... :surprised:
Offline DamoP
  • -Receive: 115
« Reply #9 on: October 25, 2014, 08:37:27 pm »
i did this mod on my old golf. i was swinging on the panel and it wasnt moving  :signLOL:
