Author Topic: Dazza's Maintenance Thread  (Read 189286 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Dazza's Maintenance Thread
« Reply #105 on: February 11, 2015, 04:35:18 pm »
Still working on the sub box.  :confused:
More trimming down. The angle grinder and a 60 grit disk made short work of the Fiberglass.
The back of the box was a bit of a mess a few air spaces next to the bulk mat. Filled this with some filler.
« Last Edit: February 12, 2015, 11:57:54 pm by dazza »
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #106 on: February 13, 2015, 06:21:41 pm »
Cant believe it. Well happy with my self.
Sub box is finished 20L capacity.
Offline gixerben
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92657.msg930393.html#msg930393
« Reply #107 on: February 13, 2015, 07:57:02 pm »
Great workmate, looks very pro. the cloth looks a good match where did you pick that up?
Pirelli GTI
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Offline gixerben
« Reply #109 on: February 13, 2015, 08:11:44 pm »
I could use the left overs to recover the lounge carpet :grin: thanks for the link, may come in handy if and when i start my build.
Pirelli GTI
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #110 on: February 13, 2015, 08:49:10 pm »
Great work Dazza! Your dedication (aka OCD) paid off! It's beautifully done! :notworthy:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #111 on: February 13, 2015, 09:02:20 pm »
Thanks mate. I can't wait to get it all finished. Even treated my self to a new soldering iron.  :drool:
Now that the sub box is done i can start on mounting the amps. Still need to switch out the passenger speakers and decide if i will do anything with the rears.
« Reply #112 on: February 13, 2015, 09:49:51 pm »
Looking good mate!
Offline jedi-knight83
  • -Receive: 41
« Reply #113 on: February 14, 2015, 02:11:20 pm »
thats quite some soldering iron!? whats the extra box. Mines just a bog standard one and I'm rubbish at soldering lol.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #114 on: February 14, 2015, 03:10:33 pm »
Looking good mate!
What the Iron or the box??
Its much easier to solder with a decent Iron. Also i've been told the solder makes a big difference as well. I've done a bit of testing the joints seem much cleaner. Solder melts instantly when you touch it with the iron. Not bad for £45. My old iron was 30w this is 60w with temperature control.
« Last Edit: February 14, 2015, 03:13:52 pm by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #115 on: February 16, 2015, 05:29:24 pm »
Mounted the amps and sh*t today. Not to happy with the placement of everything but i've had enough now so it will have to do.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #116 on: February 17, 2015, 05:58:33 pm »
Can't believe how much time i'm spending on this  :stupid:
Run remote from fusebox set up relay and powered everything up.
Installed the other HSK in the passenger door.
Still not happy with the placement of everything.  :sad1:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #117 on: February 17, 2015, 11:02:58 pm »
For me the placement looks great! :grin:
How did you find the sound with both sides fitted? :smiley:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #118 on: February 18, 2015, 12:43:47 am »
I decided as all i needed to do was plug in a couple of wires i would get it all up and running. Easy i thought.
Not so I think the LC6I i bought off eBay is fooked. The channel for the sub should be automatic when it has no signal it should take the signal from the main channel. This did not work.
So i thought as i have cut and run the rear speaker wires to the boot i could use this for the sub. But as i've cut the rear wires the HU no longer sees the rear speakers so i have no fader.
Fixed this with VAGCOM changing option to SoundSystem installed. But now its sending out a Low level output. Surely this cant be run through a line out converter??
Anyway bridged the amp to the fronts (180 W RMS) not really tested it as the kids were asleep.  :sad1:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #119 on: February 20, 2015, 07:49:16 pm »
Wiring on hold awaiting more bits and bobs.
Added a bit of perspex and test cut some vinyl wrap.
