Author Topic: Dazza's Maintenance Thread  (Read 188782 times)
Re: Dazza's Maintenance Thread
« Reply #195 on: July 17, 2015, 11:13:35 am »
Thanks mate!
I use Dodo Juice Supernatural Tyre Dressing.
Maybe the detailing gurus can recommend something even better.
Meguires endurance is good
Mattwoodison
« Reply #196 on: July 17, 2015, 08:40:48 pm »
Where did you feed the wire from the battery to the amp thru the engine bay? I've done them before but can't find an easy way thru...?
I have DSG so there is a hole where the clutch would be.
Me too, I'll have a look. If not I'll try behind the glove box
Offline TForrest94
« Reply #197 on: July 18, 2015, 11:19:27 am »
Remove the battery and the holder, below that follow the loom to find the grommet in the fire wall, when I did it I cut one of the rubber udders off (you will know when you see them) poke some firm wire through and it will come out quite high up in the passenger footwell (uk cars)
Its just a way of life.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #198 on: August 08, 2015, 11:33:17 pm »
Washed the car this morning then got caught in the rain this afternoon  :sad1:
I usually take the beater if there is a chance of rain but its currently parked 2km away from my house due to all the tourists taking my spot :fighting:
Think i may try some hard protection for the paint can anyone recommend anything? Its 30º+ at the moment and dusty.
Did manage to fit the Climair wind deflectors this week. Fooking expensive but i do like them.
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #199 on: August 14, 2015, 01:20:52 pm »
When installing my interior LED's i noticed the glove box light was not working.
There was no switch on the back of the glove box which was a bit strange.
Took the glovebox out today its been removed before and someone made a complete mess of it. What job would need the glove box removed?
The screw above the ashtray was completely sheared off 2 of the remaining screws were missing a controller that should be secured to the side of the glovebox was just flapping about ( i think it has something to do with the airbag as i says handle with care  :confused:) Also ac pipe for cooling the glovebox was not attached. Should there also be a trim piece that covers the cabin filter??
Installed new switch now working as expected.
« Last Edit: August 14, 2015, 06:35:41 pm by dazza »
Offline Ruggy
« Reply #200 on: August 14, 2015, 01:55:29 pm »
Yes there is supposed to be a cover over where the pollen filter goes. Mine was also missing when I bought it in February.  I'd get it replaced before winter comes round because it lets in a massive draft behind the dashboard. The car gets very cold if your driving at decent speeds.
Picked up a replacement at VW, think it was around £12
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #201 on: August 14, 2015, 01:57:46 pm »
Thanks mate any ideas on the part number?
i can see part number 19 on the pic below but it does not look correct.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #202 on: August 14, 2015, 02:00:24 pm »
What on Earth has someone done to your GTI? :confused:
I think there's a module behind the glove box compartment, other than that I don't know why someone would want to remove it? Just to pass cables it's not really required to remove it...
The cabin filter has a kind of foam cover, fixed by two plastic screws.
Offline Ruggy
« Reply #203 on: August 14, 2015, 02:07:59 pm »
It's number 13 that you want. Can't remember the part number though, sorry.
Part 19 is the foam cover that goes above the footwell.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #204 on: August 14, 2015, 02:18:22 pm »
I have the cover that slides in to hold the air filter in place. I need the carpet/foam cover for above the footwell.
Offline Ruggy
« Reply #205 on: August 14, 2015, 02:24:14 pm »
Ah right, you just need number 19 then and a couple of number 22 plastic screws to keep it in place.
Offline marko
« Reply #206 on: August 14, 2015, 02:45:44 pm »
That module that was flapping about is an afs module to do with autolevelling on xenon lamps.
Just cable tie it to something.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #207 on: August 14, 2015, 02:56:04 pm »
It was probably the dealers lol.
Thanks mate i cable tied it. Why have handle with care if its for the xenons?? When i was pulling the glove box out i thought i may get an airbag in the face.
« Last Edit: August 14, 2015, 02:58:04 pm by dazza »
Offline doylebros
  • -Receive: 310
« Reply #208 on: August 17, 2015, 10:13:18 pm »
The part you're after is item 18 on this drawing I think Dazza
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=8&grf=082020409&bf=82021&hgug=820&ug=20&parent_id=2349956
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #209 on: August 17, 2015, 11:37:54 pm »
Thanks mate i ordered one on friday hopefully they will get it this week. Little things like that really annoy me.
