Author Topic: Dazza's Maintenance Thread  (Read 188423 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Dazza's Maintenance Thread
« Reply #270 on: January 12, 2016, 11:24:06 pm »
Cant be bothered now. It's not so easy to get in and out. Will get the bluetooth fiished and have a look another day. Its been siting on my desk for 6 months as i was tired of messing with it.
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #271 on: January 12, 2016, 11:29:30 pm »
Sorry another question. What percentage have people set the fogs to when running as DRL's.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #272 on: January 13, 2016, 11:14:53 am »
Went and picked these bits up from VW this morning to finish the bluetooth install.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #273 on: January 13, 2016, 12:53:05 pm »
Fitted a new coil pack harness.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #274 on: January 13, 2016, 12:56:39 pm »
Good finishing touches. :happy2:
« Reply #275 on: January 13, 2016, 12:58:09 pm »
Daz.. have you got part numbers for those?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #276 on: January 13, 2016, 01:14:28 pm »
Cover 1K0971813C 9B9
Bracket 3C0919935A
Expanding nut N 90946001 * 2
Securing Bolts N 90817003 * 2
Bolts to hold module to bracket N 90667402 * 3
This is what i bought came to €43.50 with coil pack harness.
But the bracket is only secured to the car on one side so its not sitting 100% flush could probably bend the bracket slightly. There is another piece which holds the other side in place but not sure if it will fit our cars. See link below with the other bracket.
https://www.drive2.ru/l/7478347/
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1559&set=1564&ein=2010&f=655&hauptgr=1234567890&hg=0&grf=003556655&bf=03552&hgug=035&ug=35&parent_id=3130901
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #277 on: January 13, 2016, 01:34:02 pm »
I think the other bracket piece will fit. I have the bolts there to mount it on. Will go and order these bits later.
N 90667402 * 2
N 01508210 * 2
1K0919747
Probably cheaper to get the foam insert but i think this looks better.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #278 on: January 13, 2016, 04:39:12 pm »
I've managed to switch the bluetooth to handsfree mode rather than premium via the MFD.
Should the premium show track info and have the skip buttons? If so whats the trick to get this working with a Galaxy S5??
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #279 on: January 13, 2016, 04:45:42 pm »
The Premium module should show all that info. I have no idea what you need to do to make it happen, mine just did... I remember I had to unselect a coding option to stop making the iphone from playing music whenever I connected it to the BT module.
Offline RBS
  • -Receive: 49
« Reply #280 on: January 13, 2016, 07:09:56 pm »
Nice instal!! Didn't know that vw had this :surprised: ! As I mentioned before great thread mate :happy2:
Keep up the fine work :drinking:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #281 on: January 13, 2016, 07:58:42 pm »
Will try and get hold of a different phone, maybe its down to my Galaxy S5.
Thanks mate. Its about time i got some power mods.
« Last Edit: January 14, 2016, 10:13:02 am by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #282 on: January 14, 2016, 09:37:10 am »
I've enabled voice on the RNS-510. The star button on the radio works but the star button on the wheel just mutes. How do i activate this?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #283 on: January 22, 2016, 12:06:32 pm »
Fitted the rest of the bluetooth bracket.
IMO get the foam with the carpet cover.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #284 on: January 22, 2016, 12:21:23 pm »
Have you found how that's done?
