Author Topic: Sat 7th of feb Surrey Rolling Road day  (Read 48723 times)
Offline DANBOY66
  • -Given: 41
Re: Sat 7th of feb Surrey Rolling Road day
« Reply #135 on: February 04, 2015, 07:07:33 pm »
I will have my vcds cable
Dan..
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #136 on: February 04, 2015, 09:29:23 pm »
Check your tyre pressures guys  :happy2:
Poorly inflated tyres will affect the accuracy of the Dyno runs
And check your oil. . .   :scared:
« Last Edit: February 04, 2015, 09:36:44 pm by GrayMK5GTI »
Offline DANBOY66
  • -Given: 41
« Reply #137 on: February 05, 2015, 06:37:17 am »
We will do tyre pressure on the day so we all run the same
Less veribles  :happy2:
Dan..
« Reply #138 on: February 05, 2015, 09:30:15 am »
I wouldn't be setting tyre pressures hot.
Anyway fancy meeting up beforehand for some chow?
Just round the corner from SRR.
McDonald's - Farnborough Tumble Down Dick
FARNBOROUGH ROAD
FARNBOROUGH
HAMPSHIRE
GU14 7JT
Offline DANBOY66
  • -Given: 41
« Reply #139 on: February 05, 2015, 09:36:37 am »
Why not hot fella ?
I have over an hours drive  so I will see you alk at srr
Dan..
Offline xjay1337
  • -Receive: 377
« Reply #140 on: February 05, 2015, 09:37:30 am »
I may have to go to a 1 year olds birthday instead of this.... not sure yet....... :sad1: :sad1: :sad1:
« Reply #141 on: February 05, 2015, 09:40:29 am »
Why not hot fella ?
You should always set tyre pressures cold otherwise how do you know at what temp to set them.
If you set 35psi hot it will be 30psi cold as an example.
dansmith180
« Reply #142 on: February 05, 2015, 09:48:07 am »
I had no idea it fluctuated enough to make a difference.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #144 on: February 05, 2015, 10:40:44 am »
 :sad1: not another one dropping out
« Reply #145 on: February 05, 2015, 10:44:46 am »
The yoof of today. No staying power.
« Reply #146 on: February 05, 2015, 10:45:47 am »
Lack of commitment...
Offline xjay1337
  • -Receive: 377
« Reply #147 on: February 05, 2015, 05:29:08 pm »
Like I said I'm not sure.
I did ask what the other one wanted to do... no answer and skipped to another subject.
Blood and a stone come to mind.  :signLOL: :stupid:
Saintsteve
« Reply #148 on: February 05, 2015, 07:05:07 pm »
Sorry I did laugh... rich you are known as Mr Reliable when it comes to forum meet turnouts!?  :evilgrin:
Mind you you went to the leather Bottle and I didn't so looks like I'm from the same Kettle  :signLOL:
« Last Edit: February 05, 2015, 07:07:10 pm by Saintsteve »
Offline xjay1337
  • -Receive: 377
« Reply #149 on: February 06, 2015, 01:02:18 pm »
Still coming to this.  :notworthy: :notworthy:
