Author Topic: Mk7 R brakes on Scirocco  (Read 22138 times)
Offline xjay1337
  • -Receive: 377
Re: Mk7 R brakes on Scirocco
« Reply #15 on: January 15, 2015, 07:37:05 am »
you can buy porsche 4 pots for not far off that rich.  :chicken:
Fully refurbished?
Bit of paint and a seal kit, not that much.
Seal kit probably about £40 and powdercoating will be about 20 quid per caliper.
I just don't understand why you'd buy a set of not that good brakes for £350 + carriers + discs + pads when you can buy working, visually OK Porsche calipers which work infinitely better for £250 + carriers + discs + pads...
http://www.mk5golfgti.co.uk/forum/index.php/topic,91113.0.html
« Reply #16 on: January 15, 2015, 08:09:03 am »
No one in their right mind would referb and powdercoat for those prices. Decent job you are looking at ~100 each.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #17 on: January 15, 2015, 09:14:11 am »
Yep. If you want a proper job done by brake caliper refurbs then you are looking at a decent chunk.
Thinking of the original plan now. Ttrs/rs3 calipers. Just undecided on custom brackets to run TTS 340m discs, or chance it on the TTRS 370m discs. Which are damn expensive.
#1493
« Reply #18 on: January 15, 2015, 09:57:28 am »
I'd go down the 370mm route unless you plan to keep the car long term, thus taking advantage of cheaper 340mm consumables.
Offline Softishman
« Reply #19 on: January 15, 2015, 10:05:23 am »
I am going or TTRS calipers and 370mm discs, when time come to change the discs I will look for brackets to fit a smaller disc... But until that... :driver:
Offline xjay1337
  • -Receive: 377
« Reply #20 on: January 15, 2015, 10:41:53 am »
Rebuild the calipers at home, off the car it's easy.
If you're paying for someone else to do it, then a good chunk of the money is time.......which is fine, but if you can do it yourself, why not?
« Reply #21 on: January 15, 2015, 11:08:48 am »
Show me?? Buy some old Calipers and refurb them..... Bet you won't want to do another set.
Offline xjay1337
  • -Receive: 377
« Reply #22 on: January 15, 2015, 11:13:34 am »
I rebuilt calipers on my old motorcycle.. 4 pot R1 calipers.. rebuild kit cost me £18 and two evenings...
« Reply #23 on: January 15, 2015, 11:16:56 am »
Good for you.....
Offline vRSAlex
  • -Receive: 253
« Reply #24 on: January 15, 2015, 11:21:13 am »
Good for you.....
 :signLOL:
Follow AKS tuning on Facebook
Offline vRSAlex
  • -Receive: 253
« Reply #25 on: January 15, 2015, 11:22:15 am »
Going to say this is caps to put the point across:
DO NOT POWDERCOAT BRAKE CALIPERS.
Offline xjay1337
  • -Receive: 377
« Reply #26 on: January 15, 2015, 11:41:08 am »
Good for you.....
 :signLOL:
 :rolleye:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #27 on: January 15, 2015, 07:13:41 pm »
Now now ladies.  :grin:
Probably cheaper in the interim to go TTRS calipers, HEL lines and EBC TTRS discs. I'll be getting TTRS calipers custom painted though and rears done to match. Eventually.
Just a small matter of house sale and divorce to sort out.  :signLOL:
#1493
Offline xjay1337
  • -Receive: 377
« Reply #28 on: January 15, 2015, 07:15:09 pm »
Probably the best bang for your buck in that respect.
To keep initial costs down at least you could stick with the 370mm discs and get the carriers/discs for the 340mm when you inevitably warp the standards.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #29 on: January 16, 2015, 12:51:22 am »
Aftermarket discs prone to warp as well as the oems?
#1493
