Author Topic: Alarm issue please help  (Read 1570 times)
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« on: February 22, 2015, 07:57:30 am »
Morning all
I've had problems recently with my 2005 golf gti and the alarm keep on going off for no reason  Very frustrating ! I've had the drivers door lock module replaced last weekend because It was playing up on me and wouldn't unlock Genuine vw part
I don't think the alarm did this before I changed the module could it be a duff door lock module any help on my situation would be much appericated
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
  • -Receive: 452
Re: Alarm issue please help
« Reply #1 on: February 22, 2015, 10:04:38 am »
Could just be coincidence but suggest you get a vcds scan done as your siren could be faulty.
Offline Paultc90
« Reply #2 on: February 22, 2015, 11:30:01 am »
Had the same problem, was a dodgy door lock module that I replaced. Wasn't a genuine unit I used. Got progressively worse and alarm was going off every 5 mins and throwing on the interior lights while I was driving.
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
  • Instagram & YouTube - mateyguv
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.0.html
« Reply #3 on: February 22, 2015, 01:46:43 pm »
I had a simular alarm gremlin and it turned out to be the ignition micro switch. Scans showed up error in door module and rear boot switch which I replaced and alarm kept going off for no reason. In the end I replaced the ignition inner barrel with microswitch and good as gold. When driving can you hear clicking sounds every now and again coming from steering colum and maybe doors unlock themselfs when driving?
Offline jhook661
  • -Receive: 20
« Reply #4 on: February 22, 2015, 04:36:16 pm »
Well I went to vw heritage on Friday for dionoistics and Revo stage 1 map the only error code it came up with was the battery was disconnected ? :( what do you mean by microswitch ?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #5 on: February 22, 2015, 04:43:15 pm »
Inner ignition barrel has a micro switch to tell if the key in inserted or not. Mine was knackered and giving wrong signals to the ECU. Looks like my ignition barrel was "seeing" the key placed in and out when the alarm was set making it think an unauthorised key was in the ignition and setting alarm off. Do you here clicking from steering colum when driving?
If scan says battery disconnected it may be the alarms internal battery back up that's failed - about £85 for a new siren and battery from TPS
Offline jhook661
  • -Receive: 20
« Reply #6 on: February 22, 2015, 05:08:33 pm »
Well I dissconected the battery a few weeks back fitting my boost gauge ? It's wired how it's doing it after I replaced my door lock module :(
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #7 on: February 22, 2015, 05:16:09 pm »
It may be coincidence that it's started happening now. I should have asked earlier - do you hear clicking noises from your steering colum when driving or do the doors unlock and then relock themselves when driving?
Offline jhook661
  • -Receive: 20
« Reply #8 on: February 23, 2015, 06:10:12 pm »
No problems like that no clicking just goes off whenever it feels every now and then a bit strange to me
Offline Paultc90
« Reply #9 on: February 23, 2015, 08:25:27 pm »
Was the door module you bought brand new? Sounds exactly like the problem I had, so would say it's a dodgy door lock module.
Offline jhook661
  • -Receive: 20
« Reply #10 on: February 25, 2015, 09:23:36 pm »
Yeah brand new one from vw that's what I think dodgy door lock module
