All Things Mk5 > Performance Modifications
touran owner looking for handling info (newbie)
olethalb:
Mr wigley, and arb recommendations or handling mods worth doing. Starting to think these Kw are just too soft
grumpy:
Hi,
The best tyres you can afford is good (no heavy wheels).
TT mk2 top mounts are good.
Fresh Lemforder ball joints & drop links from eurocarparts are good.
Superpro wishbone anti lift bush is good.
KW/H&R/Eibach upgraded arbs are good.
How low are you on your KWs? If you've lowered it below the t.u.v. height your roll centre is no longer optimum... which is not good.
Cheers.
rich83:
--- Quote from: olethalb on April 10, 2015, 12:50:30 pm ---Mr wigley, and arb recommendations or handling mods worth doing. Starting to think these Kw are just too soft
--- End quote ---
ARBS... Camber up front... Superpro anti lift kit... decent alignment. Even on stock suspension that should be good.
Which KW are they? Decent adjustable coilovers are over 1000 quid. :scared:
I am looking for some decent adjustable shocks to go with lowering springs, IMO that for me would be the perfect solution.
olethalb:
--- Quote from: grumpy on April 11, 2015, 11:42:54 pm ---Hi,
Cheers.
--- End quote ---
thanks grumpy
all front end / joints / bushes are couple of k miles old
i'm not too concerned about wheels / tyres i just don't want it to feel like it's going to fall over when you turn in.
my old derv touran was on AP's and 19x8.5 wheels and handled very well (for a bus)
i'll get some mk2 tt topmounts then for when i lay my hands on AP's, the KW are as low as they can go but theres no chance i'll raise it :D
is the TT RARB a worthwhile upgrade?
olethalb:
--- Quote from: rich83 on April 12, 2015, 10:23:55 am ---
--- End quote ---
--- End quote ---
KW are the V1 inox line, but far too soft - i'm looking for someone to swap me some AP's
i'll take a look at this anti lift kit, i had full laser allign on it's test drive :D
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
