Author Topic: TFSI BUS TTE420 arrived  (Read 109493 times)
Offline rex
  • -Given: 50
  • -Receive: 74
Re: 7 seat GTI
« Reply #15 on: April 16, 2015, 12:29:04 pm »
rex - physical engine swap was easy part - both engines out and tfsi into touran including full front subframe / rack / heatshields / a/c pipes / mounts / milltek (extending 4" and down turns) and modifying intake pipe in 1 day
the hard part (i didn't foresee) was wiring - unlike mk4 golfs i'm used to messing with the mk5 / touran looms are pretty much one piece, half of the ecu loom is 'built in' to car loom, car loom basically runs from front lights to rear lights and everything inbetween.
after pouring 3 full days into trying to wire touran loom to work with tfsi engine i gave in, decided best option was to do full loom swap, this means every module / ecu / sensor had to be used from golf including airbag crash sensors and ignitors as touran items are not the same.
after dropping the loom in getting it running was easy, everything else took time - swapping heater boxes and controls as golf was dual zone climate, wiring rear lights (work slightly different to golf) extending many bits of loom for longer, taller touran, fitting sensors touran didn't have but golf did, converting headlights from xenon to normal, converting one (golf) wiper motor wiring to two (touran) and all sorts of things you don't even consider - washer bottle with level sensor, rain sensor, twin horns etc etc
Thought so....
The wiring is what is scaring me. But I guess it should be easier since I have a Golf.
Do you think I might have some unforeseen problems? Or any advice on how to select the 'donor' car?
Thank you  :notworthy:
Offline Bignod00
  • Ginsters are sh*tE!!
Re: 7 seat GTI
« Reply #16 on: April 16, 2015, 12:50:02 pm »
Epic build, an awesome amount of work too which is great to see! :party:
I'd love to own this car, the joy of seeing the look on people faces when it flys down the road would be brilliant! :laugh:
If it was me I'd 100% have a TDi badge on the rear just to really add to the effect! :happy2:
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: 7 seat GTI
« Reply #17 on: April 16, 2015, 01:11:02 pm »
rex - if you're really planning on doing it i have some rough wire translations. if you have full car it's not terrible - rear end wiring took a fair time as wires aren't even close to similar colours. i'd get the nearest spec 5 door golf i could.
i had to buy a few parts off ebay as i'd left them in the golf - side airbag ignitors (behind b pillar trim) crash sensors (inside doors on golf) touran doesn't have them. also where i converted to climatronic i needed a 'sun sensor' that fits touran dash (on top centre) and that plugs into golf loom.
there's a few things like airbag plugs different so need chopping off touran loom and soldering to golf loom, golf has tweeters in front door loom where touran has them in the dash
clocks didn't drop straight in, took a bit of shaving to get them into the dash, exhaust is the same all the way through but is longer on the touran around the rear wheel area, all hangers before and after match up but needs extending just before the rear wheel.
front subframe / rack etc is all the same fitment as are struts
the touran fsi pump seems to be a mash up of mk5 and mk4 but you can simply bolt the golf pump pot part to the sender and top of touran pump, you'll need to tend to fuel lines too and fit golf 6.6 bar filter and remove one of the touran return lines from the engine bay (blue)
Bignod00 - thanks bud, people hear the noise and chatter and look around bemused trying to see what that sound was as it certainly wasn't that family wagon  :grin:
regards badge it's still wearing the 1.6 FSI badge with pride  :happy2:
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline Lyons
  • -Given: 18
Re: 7 seat GTI
« Reply #18 on: April 16, 2015, 01:16:24 pm »
That is absolutely awesome.
Some Touran/Golf 16/17" alloys would just complete the sleeper look.
Offline JaseGti
    • Remoteclothing
Re: 7 seat GTI
« Reply #19 on: April 16, 2015, 05:50:32 pm »
Legend that is all :driver:
CW is the way forwards
Remoteclothing.com
Offline olethalb
  • -Receive: 31
Re: 7 seat GTI
« Reply #20 on: April 17, 2015, 01:34:21 pm »
lyons - thanks bud, unfortunately i need all the help / width i can get to get traction - agreed purchase of some 18x9's earlier
JaseGti -  :signLOL: just a silly thing i wanted to do since owning a dirty diesel touran a couple of years ago, always fancied a petrol one with power. seeing as the biggest petrol model they do is the 1.6 fsi powerhouse @104bhp  :notworthy: i had to build one.
Offline olethalb
  • -Receive: 31
Re: 7 seat GTI
« Reply #21 on: April 20, 2015, 08:31:54 am »
Picked up the tt speedlines
Tried one on
Didn't like them at all so put them back on ebay
Fitted my new AP that arrived thursday after ordering wednesday afternoon  :happy2:
And some 19x8.5 helios
Also an auto headlight switch
Re: 7 seat GTI
« Reply #22 on: April 20, 2015, 10:20:28 am »
 :notworthy: :notworthy:
Offline Bignod00
Re: 7 seat GTI
« Reply #23 on: April 21, 2015, 07:42:50 am »
More great work buddy, so......how long till the Quattro conversion? :happy2:
Offline Andy-GTI
Re: 7 seat GTI
« Reply #24 on: April 21, 2015, 09:18:47 pm »
Quality build! bet it surprises a few people. :fighting:
Keep up the good work :drinking:
Offline Spankiee
  • -Receive: 20
Re: 7 seat GTI
« Reply #25 on: April 22, 2015, 08:29:05 am »
I liked the speed line wheels most to be honest.
Still looks good on the latest wheels you have though.
candy white edition 30
Offline tommy_d
Re: 7 seat GTI
« Reply #26 on: April 22, 2015, 04:30:34 pm »
What an interesting build.
Nice to see people doing new and different things.
Offline olethalb
  • -Receive: 31
Re: 7 seat GTI
« Reply #27 on: April 27, 2015, 09:04:42 am »
hedge -   :happy2:
skard - most of it's laying around the workshop  :grin:
Bignod - thanks bud, decided to sort the interior and bodywork then start looking at quattro conversion
Andy-GTI - it has suprised a couple of people, i haven't really 'raced' anything in it, just people sat on my bumper i drop it down a cog or 2 and they don't seem to keen to sit up my butt anymore  :wink:
spankiee - i like them off the car but when they went on they were just too small looking. i've always fancied some helios and i think they suit this rather well.
tommy_d - thanks bud, it's been something i've wanted to do for a couple of years now and was finally in a position to do it.
Offline olethalb
  • -Receive: 31
Re: 7 seat GTI
« Reply #28 on: April 27, 2015, 09:22:22 am »
A few things happened in the last week....
Polish woman nearly had a head on with me, she was coming around a turn at high speed on my side of the road at night, only option was to throw it up the verge / curb
Luckily the guy i bought the wheels off had a fifth and dropped it down to me
Made a mount for intake
Washed engine bay
Fitted powerflex bone bush
Fitted passat r36 rear arb
And gti rear splash guards
Mk5 interior monitor button arrived from ebay so dropped that in
Collected some touran sport seats off ebay
New vs old
All in
I also wired in and fitted mk5 alarm sensors (unfortunately no room in the headliner)
I wired in the rain/ light sensor too but waiting on special order parts to complete installation, i found this in a box of random parts from the mk5 so i've ordered adaptor lead to see if it works
Offline olethalb
  • -Receive: 31
Re: 7 seat GTI
« Reply #29 on: April 29, 2015, 09:09:05 am »
was having a slow day at work yesterday so made a list of all the parts swapped / extras / upgrades etc
S3 BHZ complete engine
RS4 FPV
G rev dv
Autotech HPFP
3" decat downpipe
Milltek custom cat back
Uprated fmic
Uprated clutch
Revo intake custom
K&N filter
Storm stage 2+ remap - 370bhp 354ftlbs
TTS engine cover
6.6 bar fuel filter
Golf GTI 6 speed gearbox and driveshafts
Golf GTI subframe assembly / rack / hubs
Powerflex wishbone front bushes
New golf GTI engine mounts
Poweflex dogbone bush
Golf GTI bulkhead heatshields / a/c pipes / clutch line
Golf GTI fuse / relay box / panel
Golf GTI battery box
Full golf GTI wiring loom
Twin horn upgrade
Twin pump / level sensor washer bottle
Heated windscreen washers
Foglights
Auto headlights
Auto wipers
Alarm system with siren / interior monitor / anti jack
Golf GTI clocks
Golf GTI gearknob
Golf GTI steering wheel
Dual zone climatronic upgrade
Rcd 300 mp3 stereo -  silver buttons
Iphone  interface
Touran sport interior with tables and picnic function
Golf GTI pedals
Golf GTI intank fuel pump
Golf GTI pump controller
Golf GTI fuel lines
Golf GTI carbon canister
R36 rear anti roll bar
VWR front anti roll bar
DTM 320mm front brakes
GTI rear brakes + splash shields
AP coilovers
19 x 8.5 helios wheels
Votex side skirts
Votex rear valance
Chrome tip window switches
Alu headlight switch
Golf GTI radiator
Golf GTI a/c radiator / pipes
Golf GTI abs pump
Footwell lights
Golf GTI wiper stalk
Golf GTI can gateway
Golf GTI column computer / slip ring / angle sensor
Golf GTI CCM
Golf GTI CEM
NEW PARTS
Discs and pads all round
Cambelt kit and water pump
Cam follower
PCV
Plugs
All fluids
Ball joints
ARB bushes
Wishbone rear bushes
Track rod ends
Drop links
Sun sensor
Drivers door handle
Scuttle panel
Leather gear gator
Stereo fascia
Alarm siren
Door lock module LH/R
Matt set
Battery
Cruise control stalk and highline computer
C rev slip ring
