Author Topic: NQSBBK Brake pads moving in the calipers?  (Read 1765 times)
Offline DanBoy
  • My Ride: Mk5 Golf GT TDI and Škoda Fabia Monte Carlo
« on: June 25, 2015, 11:25:45 am »
Has anyone whose fitted the NQSBBK had any issues where the brake pads are moving in the caliper, if so how did you solve the issue??  :happy2:
Re: NQSBBK Brake pads moving in the calipers?
« Reply #1 on: June 25, 2015, 11:32:15 am »
You mean a knock when braking first time either forwards or backwards?
What pads are you using?
Offline DanBoy
« Reply #2 on: June 25, 2015, 11:36:52 am »
Yea that's it, I've got Textar pads fitted on them at the moment, the garage has just fitted my set up and mentioned it to me.
« Reply #3 on: June 25, 2015, 11:40:54 am »
TBH... is happens with some pads. My brother on his clio RS or Megane (cant remember which it happened on now) had the same problem with some pads.
Maybe try a different brand of pad.
Do the NQSBBK calipers have pad runners/guide? (cant remember their correct name)
Offline DanBoy
« Reply #4 on: June 25, 2015, 11:42:38 am »
I've just checked on my Porsche look up and the Boxsters don't have the vibration plates that the 911's seem to have, I'll have to look into what other brands I can sort.
Offline DanBoy
« Reply #5 on: June 25, 2015, 05:53:06 pm »
Just picked it up and tbh I can't hear the noise when you have the stereo on, but I'll probably uprate the discs and pads at a later date so hopefully it will sort the issue.
Offline AIR_CHILLED
« Reply #6 on: June 30, 2015, 09:40:12 pm »
Hello Danboy,
What you need are anti-squeal / rattle shims for 36 & 40mm pistons.
You can find them on Eurocarparts and manually search under Porsche 911 3.4 litre, cira 90's build, they are approx £9 each and you'll need 4.
recently fitted these brakes., they are great!
