Author Topic: EGR not working?  (Read 2428 times)
Offline ReflexRob
EGR not working?
« on: June 25, 2015, 07:04:34 pm »
My 2005 GTI with 49k on the clock doesn't idle very smoothly,  the needle doesn't move but you can feel rough idling through the floor.
I removed the oil cap with the engine running and it made a gurgling noise but the engine still ran smooth.
Do I have EGR failure?
Offline Ricky123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
Re: EGR not working?
« Reply #1 on: June 26, 2015, 01:22:14 am »
I'm sure tfsi' don't have an egr??   :confused:
Common poor idle faults can be pcv, coil pack, spark plug and even carbon build up on intake valves.
Is your engine management light on?
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline MrACD
« Reply #2 on: June 26, 2015, 08:16:14 am »
That usually would point to the PCV, probs needs replacing.  When I took out the oil dipstick (2 seconds) it started spluttering and running rough.  So if yours doesn't I look at getting that changed to start with  :happy2:
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
Offline ReflexRob
« Reply #3 on: June 26, 2015, 01:41:15 pm »
Cheers chaps - you are right I meant PCV, not EGR!  :rolleye:
Will check the dipstick method and post back.....
Offline ReflexRob
« Reply #4 on: June 27, 2015, 10:21:57 pm »
Ok,  pulled the dip stick.
Slight change in the way the car idled but no huge change....?
Offline Tony5haw2015
« Reply #5 on: July 01, 2015, 10:43:00 pm »
Dont know much about this however my 06 gti was running bad, rough idle, car would gain rpm at idlle to 1400rpm and back , turned out to be a 180 degree pipe from pcv easier to show you
http://i426.photobucket.com/albums/pp343/SpeeDemon2437/Rear%20Sway%20Bar%20DIY/Rear%20Stress%20Bar%20DIY/Front%20Sway%20Bar%20DIY/PCV%20Fix%20DIY/stockpcvvalve.jpg
Sent from my SM-G901F using Tapatalk
« Reply #6 on: July 01, 2015, 10:43:27 pm »
The pipe cracks easily and doesnt seem to seal very well causing idle issues
« Reply #7 on: July 01, 2015, 10:43:52 pm »
Deffo check it out before anything else as its a cheap fix
Offline ReflexRob
« Reply #8 on: July 06, 2015, 01:07:54 pm »
Many thanks fellas - going to replace the pcv bits
