Author Topic: How can I remove the sound pack?  (Read 10082 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: How can I remove the sound pack?
« Reply #15 on: January 25, 2010, 07:34:51 am »
I don't understand why you can't code for Dynaudio - I did one last night which was an A revision now C revision after firmware update.
Stu...
cameluk
« Reply #16 on: January 25, 2010, 01:39:52 pm »
Excuse my stupidity but is the above list options accesible through the unit its self or via VCDS and what do the highlighted options relate too?
They are only accessible via vag com mate. The ones that are highlighted are for if you have the VW soundpack installed. (dynaudio)
So if I dont have the dynoaudio speakers/amp set up I should select the other options on the unit via VAG COM/ VCDS?????  Any chance you could point out which ones?
Sound System Correction
-Sound System not installed
-Volkswagen Sound System (DDP DSP)
-Skoda Soundsystem (CAN DSP)
-Dynaudio Sound System (DDP DSP)
-Volkswagen Sound System (BAP DSP)
-Dynaudio Sound System (BAP DSP)
Speaker Channels
-Sound System (active Speakers)
-2 Speaker Channels (2 passive Front Speakers)
-4 Speaker Channels (2 passive Speakers each Front and Rear)
Treble Speaker Monitoring
-Treble Speaker Monitoring deactivated (Sound System)
-Treble Speaker Monitoring for Front Speakers active
-Treble Speaker Monitoring for Rear Speakers active
-Treble Speaker Monitoring for Front & Rear Speakers active
Offline holepunch
« Reply #17 on: January 25, 2010, 07:15:51 pm »
Thanks for the help on this, I really appreciate the assistance.
The unit should hopefully arrive tomorrow but I won’t have chance to fit it for a week or so but this should give me chance to sort out the Can Bus issue and which route I’m going to take for the DAB ariel.
Then I’ll have to get it all coded up somehow.  :scared:
Offline Garth
    • My Build thread
« Reply #18 on: February 01, 2010, 11:07:31 am »
Because I'm unlucky  :sad1:
Does anyone know if this might have anything to do with the can gateway? I never bothered replacing mine as I'm sure the battery drain issue is an old wives tale! I've had the head unit in for ages now with no problems.
vRStu, how/where do you get the new firmware for an RCD510 (not RNS510)?
Also, I'm looking for a VW premium blutooth kit  that integrates with the RCD510. I'm not bothered about any other features, as long as I can get the list of contacts on the head unit and use the phone button on the MFSW. Can you stioll sort me out with this? If so, how much?
Cheers mate
Offline Garth
    • My Build thread
« Reply #19 on: February 17, 2010, 11:57:42 am »
We finally managed to code up my RCD510 for the soundpack last night  :laugh:
I used the guide for setting up the RNS510 found on www.my-gti.com
All of the bits have to b set correctly, if only 1 is not on the correct setting, the head unit will not accept the code. The confusion came from the options being very slightly different on VCDS to what was shown on the guide, so we chose the similar options and it worked at last!
Thanks to mortygttdi again for all his patience with me  :happy2:
Offline holepunch
« Reply #20 on: February 17, 2010, 07:36:32 pm »
Was this the guide you used?  It means nothing to me but hopfully the guy whos coding and fitting my canbus/RCD510 DAB will understand it.
 http://www.my-gti.com/1411/volkswagen-rns-510-coding-when-installing-with-a-factory-amplifier
Offline Garth
    • My Build thread
« Reply #21 on: February 17, 2010, 07:51:03 pm »
That's the one, yes
