Author Topic: Is this my coilpacks?  (Read 3930 times)
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
« on: July 08, 2015, 10:44:44 pm »
Driving home from work today and decided to boot it a bit after it was warmed up and my eml flashed and car juddered in second and lost power. So tested it out a bit and it's doing it most times under heavy load. I don't have a juddering idle just under load. Any ideas?
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline RedGolfDom
Re: Is this my coilpacks?
« Reply #1 on: July 08, 2015, 11:08:12 pm »
Update plugged into vcds and have misfire in cylinder 1 and 3
Mk5 golf gt 140
Revo stage 1
Offline RedGolfDom
« Reply #2 on: July 08, 2015, 11:18:49 pm »
                Address 01: Engine       Labels: 03C-906-032-BLG.lbl
Control Module Part Number: 03C 906 032 Q    HW: 03C 906 032 C
  Component and/or Version: MED17.5.1           6456
           Software Coding: 0000072
            Work Shop Code: WSC 35604 000 1048576
                      VCID: 2B5377EE8A725A461EF-807E
3 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 119698 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:57:02
             Freeze Frame:
                    RPM: 909 /min
                    Load: 12.9 %
                    Speed: 0.0 km/h
                    Temperature: 66.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.716 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119789 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:53:04
             Freeze Frame:
                    RPM: 5916 /min
                    Load: 81.9 %
                    Speed: 84.0 km/h
                    Temperature: 86.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 119916 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:16:15
             Freeze Frame:
                    RPM: 4701 /min
                    Load: 93.7 %
                    Speed: 66.0 km/h
                    Temperature: 85.0°C
                    Temperature: 21.0°C
                    Voltage: 13.970 V
Readiness: 0000 0000
Mk5 golf gt 140
Revo stage 1
  • -Receive: 692
« Reply #3 on: July 09, 2015, 10:29:21 am »
A misfire under load usually is coilpacks, or knackered plugs.   Misfires from injectors tends to be most noticeable at idle.
Offline RedGolfDom
« Reply #4 on: July 09, 2015, 12:14:33 pm »
Thanks man! Read something about a vw recall of coilpacks os that still a thing? If not I'll just buy some new ones and a set of plugs
Mk5 golf gt 140
Revo stage 1
Offline shoaybmakda
  • -Receive: 54
« Reply #5 on: July 09, 2015, 12:43:34 pm »
I had this - had misfire on cylinder 2. Plugs were changed as part of a service by VW in February - must be packs for me I assume..
Offline bbfb10
« Reply #6 on: July 09, 2015, 12:57:04 pm »
My injector was knackered. Replaced by Midland VW.
http://www.mk5golfgti.co.uk/forum/index.php/topic,95700.0.html
Full VCDS Hex + Can.
Offline RedGolfDom
« Reply #7 on: July 09, 2015, 02:39:55 pm »
Yeah injectors would be next but hopefully the coil packs and set of plugs will fix it
Mk5 golf gt 140
Revo stage 1
Offline RedGolfDom
« Reply #8 on: July 09, 2015, 06:47:08 pm »
Going to fit tomorrow am I right in thinking it's left to right for cylinder number?
Mk5 golf gt 140
Revo stage 1
Offline Mitch H
  • -Receive: 25
« Reply #9 on: July 09, 2015, 07:02:04 pm »
Can you not swap the plugs from one cylinder to another and see if the problem follows?
And same with the coil packs
Offline RedGolfDom
« Reply #10 on: July 09, 2015, 08:41:05 pm »
I could do but if someone knows which is which it would save me probably 30 mins of messing around  :smiley:
Mk5 golf gt 140
Revo stage 1
Offline fruitmachinestu
« Reply #11 on: July 09, 2015, 09:31:04 pm »
I had my coil packs replaced on recall last week. I went in to see about the rust on the wings and they did both for free. Mine is a 56 plate gti. Hope this helps.
Offline RedGolfDom
« Reply #12 on: July 10, 2015, 12:18:42 pm »
Fitted my coil packs and plugs this morning took it for a spin and all seems good so fingers crossed it's sorted  :smiley:
Mk5 golf gt 140
Revo stage 1
Offline shoaybmakda
  • -Receive: 54
« Reply #13 on: July 11, 2015, 12:34:37 am »
My juddering was intermittent but seems to be happening more often now. Just happened three times today so think I better get it fixed before I make it worse!
Offline RedGolfDom
« Reply #14 on: July 11, 2015, 06:56:18 am »
Mine happened every time under load mate. Whether it was the coil packs or spark plugs I'm unsure but get it plugged into vcds and see the exact problem and hopefully it will be as easy fix as mine!
Mk5 golf gt 140
Revo stage 1
